Hi Elite! Sorry, what do you mean with "PR File"?
PR files means problem reporting files.
For more information, read here:
Ok, got it! I've included (because of the file size upload limitation) only the "ACPI" and "kext" folder, the bootlog, DCPIManager export, and the config.plist! Hope it's enough! Thank you!
Good evening
me too i have the same trouble with TB3 Hotplug on my X299 Deluxe II !!
hope found help here :)
Thank you
Good evening
Thank you
No PR files attached.
Would This Guide work for Mac Pro?
Hello guys, thanks for the guide. But I have a question,
1. she's below me as well as a picture of my info. Is it true?
2. and on the Thunderbolt Hardware section, why no driver are loader
there is someone who can help me
* Intel ACPI Component Architecture
* AML/ASL+ Disassembler version 20200110 (64-bit version)
* Copyright (c) 2000 - 2020 Intel Corporation
* Disassembling to symbolic ASL+ operators
* Disassembly of iASLVdHamP.aml, Wed Jun  3 23:23:06 2020
* Original Table Header:
*     Signature        "SSDT"
*     Length           0x000016F0 (5872)
*     Revision         0x01
*     Checksum         0xF8
*     OEM ID           "KGP"
*     OEM Table ID     "TB3HP"
*     OEM Revision     0x00000000 (0)
*     Compiler ID      "INTL"
*     Compiler Version 0x20200110 (538968336)
DefinitionBlock ("", "SSDT", 1, "KGP", "TB3HP", 0x00000000)
    External (_SB_.PCI0, DeviceObj)
    External (_SB_.PCI0.RP05, DeviceObj)
    External (_SB_.PCI0.RP05.PXSX, DeviceObj)
    External (DTGP, MethodObj)    // 5 Arguments
    External (PXSX, DeviceObj)
    Scope (_SB.PCI0.RP05)
        Scope (PXSX)
            Name (_STA, Zero)  // _STA: Status
        Method (_RMV, 0, NotSerialized)  // _RMV: Removal Status
            Return (Zero)
        Device (UPSB)
            Name (_ADR, Zero)  // _ADR: Address
            OperationRegion (A1E0, PCI_Config, Zero, 0x40)
            Field (A1E0, ByteAcc, NoLock, Preserve)
                AVND,   32,
                BMIE,   3,
                Offset (0x18),
                PRIB,   8,
                SECB,   8,
                SUBB,   8,
                Offset (0x1E),
                    ,   13,
                MABT,   1
            Method (_BBN, 0, NotSerialized)  // _BBN: BIOS Bus Number
                Return (SECB) /* \_SB_.PCI0.RP05.UPSB.SECB */
            Method (_STA, 0, NotSerialized)  // _STA: Status
                Return (0x0F)
                Return (Zero)
            Method (_DSM, 4, Serialized)  // _DSM: Device-Specific Method
                If (!Arg2)
                    Return (Buffer (One)
                         0x03                                             // .
                Return (Package (0x06)
                    "AAPL,slot-name",
                    Buffer (0x09)
                        "Built In"
                    "built-in",
                    Buffer (One)
                         0x00                                             // .
                    "PCI-Thunderbolt",
                    One
            Device (DSB0)
                    AVND,   32,
                    BMIE,   3,
                    Offset (0x18),
                    PRIB,   8,
                    SECB,   8,
                    SUBB,   8,
                    Offset (0x1E),
                        ,   13,
                    MABT,   1
                    Return (SECB) /* \_SB_.PCI0.RP05.UPSB.DSB0.SECB */
                    Return (0x0F)
                    Return (Zero)
                    If (!Arg2)
                             0x03                                             // .
                        "AAPL,slot-name",
                        Buffer (0x09)
                            "Built In"
                        "built-in",
                        Buffer (One)
                             0x00                                             // .
                        "PCIHotplugCapable",
                        One
                Device (NHI0)
                    Name (_STR, Unicode ("Thunderbolt"))  // _STR: Description String
                        Return (Zero)
                        AVND,   32,
                        BMIE,   3,
                        Offset (0x18),
                        PRIB,   8,
                        SECB,   8,
                        SUBB,   8,
                        Offset (0x1E),
                            ,   13,
                        MABT,   1
                    Method (_DSM, 4, NotSerialized)  // _DSM: Device-Specific Method
                        If ((Arg2 == Zero))
                                 0x03                                             // .
                        Local0 = Package (0x0D)
                                "AAPL,slot-name",
                                Buffer (0x07)
                                    "Slot-4"
                                "built-in",
                                Buffer (One)
                                     0x00                                             // .
                                "device_type",
                                Buffer (0x19)
                                    "Thunderbolt 3 Controller"
                                "model",
                                Buffer (0x22)
                                    "GC-Alpine Ridge Thunderbolt 3 NHI"
                                "name",
                                Buffer (0x27)
                                    "GC-Alpine Ridge Thunderbolt Controller"
                                "power-save",
                                One,
                                Buffer (One)
                                     0x00                                             // .
                        DTGP (Arg0, Arg1, Arg2, Arg3, RefOf (Local0))
                        Return (Local0)
                    Return (Zero)
            Device (DSB1)
                Name (_ADR, 0x00010000)  // _ADR: Address
                Name (_SUN, 0x04)  // _SUN: Slot User Number
                    AVND,   32,
                    BMIE,   3,
                    Offset (0x18),
                    PRIB,   8,
                    SECB,   8,
                    SUBB,   8,
                    Offset (0x1E),
                        ,   13,
                    MABT,   1
                    Return (SECB) /* \_SB_.PCI0.RP05.UPSB.DSB1.SECB */
                    Return (0x0F)
                    Return (Zero)
                Method (_PRW, 0, NotSerialized)  // _PRW: Power Resources for Wake
                    Return (Package (0x02)
                        0x69,
                        0x03
                    If (!Arg2)
                             0x03                                             // .
                    Return (Package (0x04)
                        "AAPL,slot-name",
                        Buffer (0x07)
                            "Slot-4"
                        "built-in",
                        Buffer (One)
                             0x00                                             // .
                Device (UPS0)
                    OperationRegion (ARE0, PCI_Config, Zero, 0x04)
                    Field (ARE0, ByteAcc, NoLock, Preserve)
                        AVND,   16
                        Return (Zero)
                    Device (DSB0)
                            AVND,   32,
                            BMIE,   3,
                            Offset (0x18),
                            PRIB,   8,
                            SECB,   8,
                            SUBB,   8,
                            Offset (0x1E),
                                ,   13,
                            MABT,   1,
                            Offset (0x3E),
                                ,   6,
                            SBRS,   1
                            Return (SECB) /* \_SB_.PCI0.RP05.UPSB.DSB1.UPS0.DSB0.SECB */
                            Return (0x0F)
                            Return (Zero)
                        Device (DEV0)
                                Return (0x0F)
                                Return (Zero)
                    Device (DSB3)
                        Name (_ADR, 0x00030000)  // _ADR: Address
                            AVND,   32,
                            BMIE,   3,
                            Offset (0x18),
                            PRIB,   8,
                            SECB,   8,
                            SUBB,   8,
                            Offset (0x1E),
                                ,   13,
                            MABT,   1
                            Return (SECB) /* \_SB_.PCI0.RP05.UPSB.DSB1.UPS0.DSB3.SECB */
                            Return (0x0F)
                            Return (Zero)
                        Device (UPS0)
                                AVND,   16
                                Return (Zero)
                            Device (DSB0)
                                    AVND,   32,
                                    BMIE,   3,
                                    Offset (0x18),
                                    PRIB,   8,
                                    SECB,   8,
                                    SUBB,   8,
                                    Offset (0x1E),
                                        ,   13,
                                    MABT,   1,
                                    Offset (0x3E),
                                        ,   6,
                                    SBRS,   1
                                    Return (SECB) /* \_SB_.PCI0.RP05.UPSB.DSB1.UPS0.DSB3.UPS0.DSB0.SECB */
                                    Return (0x0F)
                                Device (DEV0)
                                        Return (0x0F)
                            Device (DSB3)
                                    AVND,   32,
                                    BMIE,   3,
                                    Offset (0x18),
                                    PRIB,   8,
                                    SECB,   8,
                                    SUBB,   8,
                                    Offset (0x1E),
                                        ,   13,
                                    MABT,   1
                                    Return (SECB) /* \_SB_.PCI0.RP05.UPSB.DSB1.UPS0.DSB3.UPS0.DSB3.SECB */
                                    Return (0x0F)
                                    Return (Zero)
                                Device (DEV0)
                                        Return (0x0F)
                                        Return (Zero)
                            Device (DSB4)
                                Name (_ADR, 0x00040000)  // _ADR: Address
                                    AVND,   32,
                                    BMIE,   3,
                                    Offset (0x18),
                                    PRIB,   8,
                                    SECB,   8,
                                    SUBB,   8,
                                    Offset (0x1E),
                                        ,   13,
                                    MABT,   1
                                    Return (SECB) /* \_SB_.PCI0.RP05.UPSB.DSB1.UPS0.DSB3.UPS0.DSB4.SECB */
                                    Return (0x0F)
                                    Return (Zero)
                                Device (DEV0)
                                        Return (0x0F)
                                        Return (Zero)
                            Device (DSB5)
                                Name (_ADR, 0x00050000)  // _ADR: Address
                                    AVND,   32,
                                    BMIE,   3,
                                    Offset (0x18),
                                    PRIB,   8,
                                    SECB,   8,
                                    SUBB,   8,
                                    Offset (0x1E),
                                        ,   13,
                                    MABT,   1
                                    Return (SECB) /* \_SB_.PCI0.RP05.UPSB.DSB1.UPS0.DSB3.UPS0.DSB5.SECB */
                                    Return (0x0F)
                                    Return (Zero)
                            Device (DSB6)
                                Name (_ADR, 0x00060000)  // _ADR: Address
                                    AVND,   32,
                                    BMIE,   3,
                                    Offset (0x18),
                                    PRIB,   8,
                                    SECB,   8,
                                    SUBB,   8,
                                    Offset (0x1E),
                                        ,   13,
                                    MABT,   1
                                    Return (SECB) /* \_SB_.PCI0.RP05.UPSB.DSB1.UPS0.DSB3.UPS0.DSB6.SECB */
                                    Return (0x0F)
                                    Return (Zero)
                    Device (DSB4)
                            AVND,   32,
                            BMIE,   3,
                            Offset (0x18),
                            PRIB,   8,
                            SECB,   8,
                            SUBB,   8,
                            Offset (0x1E),
                                ,   13,
                            MABT,   1
                            Return (SECB) /* \_SB_.PCI0.RP05.UPSB.DSB1.UPS0.DSB4.SECB */
                            Return (0x0F)
                            Return (Zero)
                        Device (UPS0)
                                AVND,   16
                                Return (Zero)
                            Device (DSB0)
                                    AVND,   32,
                                    BMIE,   3,
                                    Offset (0x18),
                                    PRIB,   8,
                                    SECB,   8,
                                    SUBB,   8,
                                    Offset (0x1E),
                                        ,   13,
                                    MABT,   1,
                                    Offset (0x3E),
                                        ,   6,
                                    SBRS,   1
                                    Return (SECB) /* \_SB_.PCI0.RP05.UPSB.DSB1.UPS0.DSB4.UPS0.DSB0.SECB */
                                    Return (0x0F)
                                Device (DEV0)
                                        Return (0x0F)
                                        Return (Zero)
                            Device (DSB3)
                                    AVND,   32,
                                    BMIE,   3,
                                    Offset (0x18),
                                    PRIB,   8,
                                    SECB,   8,
                                    SUBB,   8,
                                    Offset (0x1E),
                                        ,   13,
                                    MABT,   1
                                    Return (SECB) /* \_SB_.PCI0.RP05.UPSB.DSB1.UPS0.DSB4.UPS0.DSB3.SECB */
                                    Return (0x0F)
                                    Return (Zero)
                                Device (DEV0)
                                        Return (0x0F)
                                        Return (Zero)
                            Device (DSB4)
                                    AVND,   32,
                                    BMIE,   3,
                                    Offset (0x18),
                                    PRIB,   8,
                                    SECB,   8,
                                    SUBB,   8,
                                    Offset (0x1E),
                                        ,   13,
                                    MABT,   1
                                    Return (SECB) /* \_SB_.PCI0.RP05.UPSB.DSB1.UPS0.DSB4.UPS0.DSB4.SECB */
                                    Return (0x0F)
                                    Return (Zero)
                                Device (DEV0)
                                        Return (0x0F)
                                        Return (Zero)
                            Device (DSB5)
                                    AVND,   32,
                                    BMIE,   3,
                                    Offset (0x18),
                                    PRIB,   8,
                                    SECB,   8,
                                    SUBB,   8,
                                    Offset (0x1E),
                                        ,   13,
                                    MABT,   1
                                    Return (SECB) /* \_SB_.PCI0.RP05.UPSB.DSB1.UPS0.DSB4.UPS0.DSB5.SECB */
                                    Return (0x0F)
                                    Return (Zero)
                            Device (DSB6)
                                    AVND,   32,
                                    BMIE,   3,
                                    Offset (0x18),
                                    PRIB,   8,
                                    SECB,   8,
                                    SUBB,   8,
                                    Offset (0x1E),
                                        ,   13,
                                    MABT,   1
                                    Return (SECB) /* \_SB_.PCI0.RP05.UPSB.DSB1.UPS0.DSB4.UPS0.DSB6.SECB */
                                    Return (0x0F)
                                    Return (Zero)
                    Device (DSB5)
                            AVND,   32,
                            BMIE,   3,
                            Offset (0x18),
                            PRIB,   8,
                            SECB,   8,
                            SUBB,   8,
                            Offset (0x1E),
                                ,   13,
                            MABT,   1
                            Return (SECB) /* \_SB_.PCI0.RP05.UPSB.DSB1.UPS0.DSB5.SECB */
                            Return (0x0F)
                            Return (Zero)
                    Device (DSB6)
                            AVND,   32,
                            BMIE,   3,
                            Offset (0x18),
                            PRIB,   8,
                            SECB,   8,
                            SUBB,   8,
                            Offset (0x1E),
                                ,   13,
                            MABT,   1
                            Return (SECB) /* \_SB_.PCI0.RP05.UPSB.DSB1.UPS0.DSB6.SECB */
                            Return (0x0F)
                            Return (Zero)
            Device (DSB2)
                Name (_ADR, 0x00020000)  // _ADR: Address
                    AVND,   32,
                    BMIE,   3,
                    Offset (0x18),
                    PRIB,   8,
                    SECB,   8,
                    SUBB,   8,
                    Offset (0x1E),
                        ,   13,
                    MABT,   1
                    Return (SECB) /* \_SB_.PCI0.RP05.UPSB.DSB2.SECB */
                    Return (0x0F)
                    Return (Zero)
                    If (!Arg2)
                             0x03                                             // .
                        One,
                        "IOPCIHPType",
                        0x02
                Device (XHC5)
                        If ((Arg2 == Zero))
                                 0x03                                             // .
                        Local0 = Package (0x14)
                                "AAPL,slot-name",
                                Buffer (0x07)
                                    "Slot-4"
                                "built-in",
                                Buffer (One)
                                     0x00                                             // .
                                "model",
                                Buffer (0x16)
                                    "GC-Alpine Ridge USB-C"
                                "name",
                                Buffer (0x21)
                                    "GC-Alpine Ridge USB-C Controller"
                                "device_type",
                                Buffer (0x13)
                                    "USB 3.1 Controller"
                                "USBBusNumber",
                                Zero,
                                "UsbCompanionControllerPresent",
                                One,
                                "AAPL,XHCI-clock-id",
                                One,
                                "IOPCIExpressCapabilites",
                                0x02,
                                "IOPCIHPType",
                                0x02
                        Return (Local0)
                            0x69,
                            0x03
                    Device (RHUB)
                            Return (Zero)
                        Device (SSP1)
                            Name (_ADR, One)  // _ADR: Address
                            Name (_UPC, Package (0x04)  // _UPC: USB Port Capabilities
                                0xFF,
                                0x09,
                                Zero,
                                Zero
                            Name (_PLD, Package (0x01)  // _PLD: Physical Location of Device
                                ToPLD (
                                    PLD_Revision           = 0x1,
                                    PLD_IgnoreColor        = 0x1,
                                    PLD_Red                = 0x0,
                                    PLD_Green              = 0x0,
                                    PLD_Blue               = 0x0,
                                    PLD_Width              = 0x0,
                                    PLD_Height             = 0x0,
                                    PLD_UserVisible        = 0x1,
                                    PLD_Dock               = 0x0,
                                    PLD_Lid                = 0x0,
                                    PLD_Panel              = "UNKNOWN",
                                    PLD_VerticalPosition   = "UPPER",
                                    PLD_HorizontalPosition = "LEFT",
                                    PLD_Shape              = "UNKNOWN",
                                    PLD_GroupOrientation   = 0x0,
                                    PLD_GroupToken         = 0x0,
                                    PLD_GroupPosition      = 0x0,
                                    PLD_Bay                = 0x0,
                                    PLD_Ejectable          = 0x0,
                                    PLD_EjectRequired      = 0x0,
                                    PLD_CabinetNumber      = 0x0,
                                    PLD_CardCageNumber     = 0x0,
                                    PLD_Reference          = 0x0,
                                    PLD_Rotation           = 0x0,
                                    PLD_Order              = 0x0,
                                    PLD_VerticalOffset     = 0x0,
                                    PLD_HorizontalOffset   = 0x0)
                                If ((Arg2 == Zero))
                                         0x03                                             // .
                                    "UsbCPortNumber",
                                    One
                        Device (SSP2)
                            Name (_ADR, 0x02)  // _ADR: Address
                                0xFF,
                                0x09,
                                Zero,
                                Zero
                                ToPLD (
                                    PLD_Revision           = 0x1,
                                    PLD_Red                = 0x0,
                                    PLD_Green              = 0x0,
                                    PLD_Blue               = 0x0,
                                    PLD_Width              = 0x0,
                                    PLD_Height             = 0x0,
                                    PLD_Dock               = 0x0,
                                    PLD_Lid                = 0x0,
                                    PLD_Bay                = 0x0,
                                    PLD_Rotation           = 0x0,
                                    PLD_Order              = 0x0,
                                If ((Arg2 == Zero))
                                         0x03                                             // .
                                    "UsbCPortNumber",
                                    0x02
                        Device (HS01)
                            Name (_ADR, 0x03)  // _ADR: Address
                                0xFF,
                                0x09,
                                Zero,
                                Zero
                                ToPLD (
                                    PLD_Revision           = 0x1,
                                    PLD_Red                = 0x0,
                                    PLD_Green              = 0x0,
                                    PLD_Blue               = 0x0,
                                    PLD_Width              = 0x0,
                                    PLD_Height             = 0x0,
                                    PLD_Dock               = 0x0,
                                    PLD_Lid                = 0x0,
                                    PLD_Bay                = 0x0,
                                    PLD_Rotation           = 0x0,
                                    PLD_Order              = 0x0,
                        Device (HS02)
                            Name (_ADR, 0x04)  // _ADR: Address
                                0xFF,
                                0x09,
                                Zero,
                                Zero
                                ToPLD (
                                    PLD_Revision           = 0x1,
                                    PLD_Red                = 0x0,
                                    PLD_Green              = 0x0,
                                    PLD_Blue               = 0x0,
                                    PLD_Width              = 0x0,
                                    PLD_Height             = 0x0,
                                    PLD_Dock               = 0x0,
                                    PLD_Lid                = 0x0,
                                    PLD_Bay                = 0x0,
                                    PLD_Rotation           = 0x0,
                                    PLD_Order              = 0x0,
            Device (DSB4)
                    AVND,   32,
                    BMIE,   3,
                    Offset (0x18),
                    PRIB,   8,
                    SECB,   8,
                    SUBB,   8,
                    Offset (0x1E),
                        ,   13,
                    MABT,   1
                    Return (SECB) /* \_SB_.PCI0.RP05.UPSB.DSB4.SECB */
                    Return (0x0F)
                    Return (Zero)
                    If (!Arg2)
                             0x03                                             // .
                        "AAPL,slot-name",
                        Buffer (0x07)
                            "Slot-4"
                        "built-in",
                        Buffer (One)
                             0x00                                             // .
                Device (UPS0)
                        AVND,   16
                        Return (Zero)
                    Device (DSB0)
                            AVND,   32,
                            BMIE,   3,
                            Offset (0x18),
                            PRIB,   8,
                            SECB,   8,
                            SUBB,   8,
                            Offset (0x1E),
                                ,   13,
                            MABT,   1,
                            Offset (0x3E),
                                ,   6,
                            SBRS,   1
                            Return (SECB) /* \_SB_.PCI0.RP05.UPSB.DSB4.UPS0.DSB0.SECB */
                            Return (0x0F)
                            Return (Zero)
                        Device (DEV0)
                                Return (0x0F)
                                Return (Zero)
                    Device (DSB3)
                            AVND,   32,
                            BMIE,   3,
                            Offset (0x18),
                            PRIB,   8,
                            SECB,   8,
                            SUBB,   8,
                            Offset (0x1E),
                                ,   13,
                            MABT,   1
                            Return (SECB) /* \_SB_.PCI0.RP05.UPSB.DSB4.UPS0.DSB3.SECB */
                            Return (0x0F)
                            Return (Zero)
                        Device (UPS0)
                                AVND,   16
                                Return (Zero)
                            Device (DSB0)
                                    AVND,   32,
                                    BMIE,   3,
                                    Offset (0x18),
                                    PRIB,   8,
                                    SECB,   8,
                                    SUBB,   8,
                                    Offset (0x1E),
                                        ,   13,
                                    MABT,   1,
                                    Offset (0x3E),
                                        ,   6,
                                    SBRS,   1
                                    Return (SECB) /* \_SB_.PCI0.RP05.UPSB.DSB4.UPS0.DSB3.UPS0.DSB0.SECB */
                                    Return (0x0F)
                                Device (DEV0)
                                        Return (0x0F)
                            Device (DSB3)
                                    AVND,   32,
                                    BMIE,   3,
                                    Offset (0x18),
                                    PRIB,   8,
                                    SECB,   8,
                                    SUBB,   8,
                                    Offset (0x1E),
                                        ,   13,
                                    MABT,   1
                                    Return (SECB) /* \_SB_.PCI0.RP05.UPSB.DSB4.UPS0.DSB3.UPS0.DSB3.SECB */
                                    Return (0x0F)
                                    Return (Zero)
                                Device (DEV0)
                                        Return (0x0F)
                                        Return (Zero)
                            Device (DSB4)
                                    AVND,   32,
                                    BMIE,   3,
                                    Offset (0x18),
                                    PRIB,   8,
                                    SECB,   8,
                                    SUBB,   8,
                                    Offset (0x1E),
                                        ,   13,
                                    MABT,   1
                                    Return (SECB) /* \_SB_.PCI0.RP05.UPSB.DSB4.UPS0.DSB3.UPS0.DSB4.SECB */
                                    Return (0x0F)
                                    Return (Zero)
                                Device (DEV0)
                                        Return (0x0F)
                                        Return (Zero)
                            Device (DSB5)
                                    AVND,   32,
                                    BMIE,   3,
                                    Offset (0x18),
                                    PRIB,   8,
                                    SECB,   8,
                                    SUBB,   8,
                                    Offset (0x1E),
                                        ,   13,
                                    MABT,   1
                                    Return (SECB) /* \_SB_.PCI0.RP05.UPSB.DSB4.UPS0.DSB3.UPS0.DSB5.SECB */
                                    Return (0x0F)
                                    Return (Zero)
                            Device (DSB6)
                                    AVND,   32,
                                    BMIE,   3,
                                    Offset (0x18),
                                    PRIB,   8,
                                    SECB,   8,
                                    SUBB,   8,
                                    Offset (0x1E),
                                        ,   13,
                                    MABT,   1
                                    Return (SECB) /* \_SB_.PCI0.RP05.UPSB.DSB4.UPS0.DSB3.UPS0.DSB6.SECB */
                                    Return (0x0F)
                                    Return (Zero)
                    Device (DSB4)
                            AVND,   32,
                            BMIE,   3,
                            Offset (0x18),
                            PRIB,   8,
                            SECB,   8,
                            SUBB,   8,
                            Offset (0x1E),
                                ,   13,
                            MABT,   1
                            Return (SECB) /* \_SB_.PCI0.RP05.UPSB.DSB4.UPS0.DSB4.SECB */
                            Return (0x0F)
                            Return (Zero)
                        Device (UPS0)
                                AVND,   16
                                Return (Zero)
                            Device (DSB0)
                                    AVND,   32,
                                    BMIE,   3,
                                    Offset (0x18),
                                    PRIB,   8,
                                    SECB,   8,
                                    SUBB,   8,
                                    Offset (0x1E),
                                        ,   13,
                                    MABT,   1,
                                    Offset (0x3E),
                                        ,   6,
                                    SBRS,   1
                                    Return (SECB) /* \_SB_.PCI0.RP05.UPSB.DSB4.UPS0.DSB4.UPS0.DSB0.SECB */
                                    Return (0x0F)
                                Device (DEV0)
                                        Return (0x0F)
                                        Return (Zero)
                            Device (DSB3)
                                    AVND,   32,
                                    BMIE,   3,
                                    Offset (0x18),
                                    PRIB,   8,
                                    SECB,   8,
                                    SUBB,   8,
                                    Offset (0x1E),
                                        ,   13,
                                    MABT,   1
                                    Return (SECB) /* \_SB_.PCI0.RP05.UPSB.DSB4.UPS0.DSB4.UPS0.DSB3.SECB */
                                    Return (0x0F)
                                    Return (Zero)
                                Device (DEV0)
                                        Return (0x0F)
                                        Return (Zero)
                            Device (DSB4)
                                    AVND,   32,
                                    BMIE,   3,
                                    Offset (0x18),
                                    PRIB,   8,
                                    SECB,   8,
                                    SUBB,   8,
                                    Offset (0x1E),
                                        ,   13,
                                    MABT,   1
                                    Return (SECB) /* \_SB_.PCI0.RP05.UPSB.DSB4.UPS0.DSB4.UPS0.DSB4.SECB */
                                    Return (0x0F)
                                    Return (Zero)
                                Device (DEV0)
                                        Return (0x0F)
                                        Return (Zero)
                            Device (DSB5)
                                    AVND,   32,
                                    BMIE,   3,
                                    Offset (0x18),
                                    PRIB,   8,
                                    SECB,   8,
                                    SUBB,   8,
                                    Offset (0x1E),
                                        ,   13,
                                    MABT,   1
                                    Return (SECB) /* \_SB_.PCI0.RP05.UPSB.DSB4.UPS0.DSB4.UPS0.DSB5.SECB */
                                    Return (0x0F)
                                    Return (Zero)
                            Device (DSB6)
                                    AVND,   32,
                                    BMIE,   3,
                                    Offset (0x18),
                                    PRIB,   8,
                                    SECB,   8,
                                    SUBB,   8,
                                    Offset (0x1E),
                                        ,   13,
                                    MABT,   1
                                    Return (SECB) /* \_SB_.PCI0.RP05.UPSB.DSB4.UPS0.DSB4.UPS0.DSB6.SECB */
                                    Return (0x0F)
                                    Return (Zero)
                    Device (DSB5)
                            AVND,   32,
                            BMIE,   3,
                            Offset (0x18),
                            PRIB,   8,
                            SECB,   8,
                            SUBB,   8,
                            Offset (0x1E),
                                ,   13,
                            MABT,   1
                            Return (SECB) /* \_SB_.PCI0.RP05.UPSB.DSB4.UPS0.DSB5.SECB */
                            Return (0x0F)
                            Return (Zero)
                    Device (DSB6)
                            AVND,   32,
                            BMIE,   3,
                            Offset (0x18),
                            PRIB,   8,
                            SECB,   8,
                            SUBB,   8,
                            Offset (0x1E),
                                ,   13,
                            MABT,   1
                            Return (SECB) /* \_SB_.PCI0.RP05.UPSB.DSB4.UPS0.DSB6.SECB */
                            Return (0x0F)
                            Return (Zero)
Thanks for this guide.
I can get it work on my HP EliteBook 850 G5. I have thunderbolt in legacy mode in BIOS and I can connect USB-C drive.
However it breaks sleep mode. When I tried to wake from sleep I needed to shut down and start again with this error:
panic(cpu 2 caller 0xffffff7f9e352399): "NHI0(MacBookPro15,4): thunderbolt power on failed 0xffffffff\n"@/AppleInternal/BuildRoot/Library/Caches/com.apple.xbs/Sources/IOPCIFamily/IOPCIFamily-370.100.21/IOPCIBridge.cpp:1398
Backtrace (CPU 2), Frame : Return Address
0xffffff83d77ab9e0 : 0xffffff801d91f5cd
0xffffff83d77aba30 : 0xffffff801da58b05
0xffffff83d77aba70 : 0xffffff801da4a68e
0xffffff83d77abac0 : 0xffffff801d8c5a40
0xffffff83d77abae0 : 0xffffff801d91ec97
0xffffff83d77abbe0 : 0xffffff801d91f087
0xffffff83d77abc30 : 0xffffff801e0c27cc
0xffffff83d77abca0 : 0xffffff7f9e352399
0xffffff83d77abcc0 : 0xffffff7f9e339fcf
0xffffff83d77abd20 : 0xffffff7f9e33a180
0xffffff83d77abd60 : 0xffffff7f9e33a334
0xffffff83d77abda0 : 0xffffff7f9e33a4fc
0xffffff83d77abdc0 : 0xffffff7f9e3386f6
0xffffff83d77abe10 : 0xffffff7f9e34301f
0xffffff83d77abe30 : 0xffffff801e0148a4
0xffffff83d77abea0 : 0xffffff801e0146aa
0xffffff83d77abec0 : 0xffffff801d961565
0xffffff83d77abf40 : 0xffffff801d961091
0xffffff83d77abfa0 : 0xffffff801d8c513e
Kernel Extensions in backtrace:
com.apple.iokit.IOPCIFamily(2.9)[BE052F4D-9B80-3FCD-B36D-BACB7DEE0DF2]@0xffffff7f9e331000->0xffffff7f9e369fff
raymondleung416
