[SOLVED] disabling Nvidia GT635m on Lenovo IdeaPad Z500
sinamcr7
Lenovo Z500
Intel Core i7 3632QM
Nvidia Geforce GT-635m
10.13.x
Hi
I want to disable Nvidia via patching and use it through windows but at the beginning of guide it needs to run 2 grep commands but when I run them, it returns no result.
what should I do?
Hi
what should I do?
Which commands?
these commands
grep -l Method.*_OFF *.dsl
grep -l Method.*_INI *.dsl
Did you set the directory to your origin folder? Also, was the DSDT and SSDT disassembled?
thank you so much it finally fixed
NazranSami3
