Apple logo and progress load bar not appear on the Clover boot screen
mehmetyuksel
Hp Probook 450 G6
Core i7
intel uhd 620
10.13.x
my system is working stably, but after selecting boot disk Apple logo and progress load bar not appear on the Clover boot screen.
Note: I used my old EFI, conflict.plist and ACPI on the attach files
Please fix your CPU model in profile.
Incomplete PR files attached. Kextcache output and EFI is missing.
ACPI is not patched properly.
Reactions: mehmetyuksel
Clover bootloader issiue: Apple progress load bar not appeared when clover 5107 from to 5115. But, in the clover 5107 is not a problem.
As indicated in my previous post, the files are not as per the guide. I'm still using the Clover from the forum. There might have been some changes. If you have fixed the above issues, provide your PR files to check.
Mark&
