help me pick up control brightness display, I use many instruction included from this thread but not working, now have slider in settings but not working. EFI
You must attach the files here only. Read here:
Follow method two
Backlight has been successfully turned on
Thanks for this
Tried method 1, it didn't worked. There is no brightness slider at SysPref --> Display, and the screen brightness is low.
PR files attached.
PR files attached.
Method 1 is depreciated now. Use Method 2.
Tried Method 2, no changes.
PR files attached.
Also, backlight is lower than normal.
PR files attached.
You must disable the NVIDIA Graphics so that the PNLF is attached to IGPU node.
If I disable discrete graphics, acceleration will work (e.g. Transparent dock)?
Optimus isn't supported. Your Laptop uses IGPU for acceleration.
Roberto Sales
