[Help] High Sierra on Dell Latitude 3480 Intel HD 620 HDMI Audio
gengstapo
Dell Inc
i5-7200U
Intel HD 620
Hello
Im looking for guidance to fix my problem
Basically, all is working on my Dell 3480 i5 7200u Kaby
My problem now is my hdmi output got no audio once connected to the external display
Other than that, i guess my hackintosh working fine
Ive included my ioreg & clover for views IF there is any space to improve my setup
Thx in advance
Hello
Thx in advance
Clover folder is large. Check FAQ thread to attach your files.
Hello
This was the spec:
  • Laptop: Dell Inc/ Latitude 3480
  • CPU: Intel i5 7200U + Intel Kaby Lake 02/ ID9D4E 21
  • Graphics: Intel HD 620 + 1366x768
  • Bootloader: Clover(UEFI)
Thx in advance
Hello
This was the spec:
Thx in advance
Your files are messed up.
Follow the guide here:
Hello
Alright, I give a try following the tutorial
Thx in advance
Hello im back
Now im installing clean HS using ur method createinstallmedia
But I got stuck where my HDMI not working properly
Can u help me with this?
This was the spec:
Thx
Hello im back
This was the spec:
Thx
Of course, we're here to help.
Here are the issues listed below
  • ACPI is not patched.
  • config.plist is not upto the mark.
  • The clover directory is not as per the guide.
  • FakePCIIDs kexts needs to be removed.
Follow the guide here: https://www.elitemacx86.com/threads...ller-on-laptops-using-clover-uefi-legacy.177/
Yes its new installation & ACPi not yet patched
Config file not upto the mark, what does this means?
The clover from the guide suggesting less kext, in the meantime i try troubleshooting at my own to see if me could solve the matters
I noticed once the Fakepciids is removed the tabs "Memory" in About This Apple is gone. Is there anyway to fix this?
Thx
The config.plist must be as per the guide.
No idea without PR files.
Problem solved
Thx all
Roberto Sales
