@EliteMacx86 I've copied the Codec Commander's kext folder in the Opencore's kext folder.
But I'm unable to copy the hda-verb file in usr/bin because I'm getting this error of read only file system in Catalina.
Yes, this is a known issue. You must enable write permission in Catalina.
Check here:
  • Love
Reactions: SniperBuddy
Check here:
Thanks a ton! Fixed it.
I have a small question. I'm unable to use a Microphone when I plug it into the same port.
How can I make Mac detect my mic?
Off topic. Create a separate thread.
@EliteMacx86
@Mirone
Hey Guys,
Thanks for this guide, but the distortion/crackling sound on both speakers and earphones is still there.
I completed the whole steps as explained
and I even added the missing ALC dictionary to the CodecCommander info.plist.
I am going to upload everything you've asked for Problem Reporting
Any help would be great
@EliteMacx86
@Mirone
Hey Guys,
Please fix your profile first.
  • config.plist is not as per the guide.
  • ACPI is not patched.
  • The drivers directory is not as per the guide.
  • Remove all the kexts installed in S/L/E.
Also, the AppleHDA looks modified and you're also using AppleALC. You should choose only one method.
neliu
