AppleACPIPlatform Kernel Panic while running macOS Sonoma installer on HM86 Motherboard
mikhailotvalovich
Lenovo ideapad Z510 HM86 chipset
i5-4200m
intel HD4600
Specs:
intel Core i5 4200m
iGpu: intel hd 4600
Chipset: HM86(Lenovo ideapad Z510)
Ram: 12GB DDR3
Rom: SSD 128gb
What should I do? I used the newest OpCore Simplify. Nothing helps.
I followed the guide and now I'm experiencing this behavior. Maybe I missed something?
video here
video here
A few corrections still has to be made:
Disable ProtectMemoryRegions and FixupAppleEfiImages quirks.
Remove AppleALCU.kext
Your Laptop is from Lenovo then what's the point in using SMCDellSensors.kext? You should remove all the sensors kext. Also, you should add CPUTscSync.kext.
UnblockFsConnect is typically required by HP systems.
The symptoms are the same, I seem to have changed everything as you asked.
TEVICHXZA
