How to install Catalina on my new laptop
mapomme1108
Asus RoG Zephyrus G14
Hello,
I have bought a new laptop
It is an Asus TuF Gaming A14 FA401UU:
  • AMD Ryzen 7 8845HS with AMD Radeon 780M Graphics
  • Nvidia GeForce RTX 4050
  • 16 Go DDR5
  • SSD NVMe 1 To WD PC SN560 SSDPNQE
  • SSD NVMe 4 To Kingston SNV2S4000G-1TTO-1102
  • MediaTek Wi-Fi 6E MT7922 (RZ616)
I have read that both the dGPU and the iGPU are not supported by macOS graphics acceleration (that comes after macOS Big Sur) so I would like to install macOS Catalina
Do you know if I can install macOS Catalina?
Thank you for your help :)
Hello,
  • 16 Go DDR5
You can install Catalina or later but the APU will NOT work!
Ok, thank you for your answer
I will try to install Tahoe first.
Any help would be very much appriciate :)
Thanks
Thanks
There is no good reason to install as having macOS without graphics acceleration would be real slow.
lupenyk
