Airport WiFi on Sequoia for Laptop Dell Latitude E5550
- What WiFi Card are you using?
Intel WiFi Hackintool says Wireless 7265
- What macOS version are you using?
MacOS Sequoi 15.7.4
- When following the WiFi guide, what errors are you getting?
No errors while modifying the config.plist
When rebooting I get a kernel panic that says: Refusing new kext, a prelinked copy with a different UUID is already present.
As I said the EFI is too big to attach but I linked up to it from my dropbox, I will repost the link below:
MacOS Sequoi 15.7.4
Your EFI is not as per the guide. Why are you injecting so many irrelevant parameters in PciRoot(0x0)/Pci(0x1C,0x3)/Pci(0x0,0x0)?
You just need to spoof and run OCLP. Once volume is patched, remove the spoof.
As expected, you have a typo. You have com.apple.iokit.IOSkyWalkFamily instead of com.apple.iokit.IOSkywalkFamily in the block section. Thus, the panic.
Also, you should try to implement Apple VT-d.
Your profile indicates you have a Dell Laptop and you should enable CustomSMBIOSGuid and set UpdateSMBIOSMode to Custom.
Why are you forcing IONetworkingFamily.kext?
Also, you should not inject AMFIPass.kext and also amfi=0x80 together
I got the EFI from this link & it worked for Ventura 100%:
Interesting just walk instead of Walk in com.apple.iokit.IOSkyWalkFamily
I will make the changes & come back, I need to redo everything like spoofing, etc...
jkzql77089
