macOS Tahoe Beta on Asus RoG Zephyrus G14
Hello,
I have followed the guide to create a EFI folder
The macOS usb installer boot but there is a black screen after this
I have attached my EFI folder
Thank you for your help :)
Hello,
I have disabled NootedRed and I can install macOS.
The installation process is ok, there is the "About xx minutes remaining" screen then it reboot and it is stuck in a reboot loop.
I had to add "-wegnoegpu" to the boot args because without it, it was stuck on the "About xx minutes remaining" screen
The latest message in the reboot loop is :
IOPlatformHaltRestartAction -> AppleSMC
Hello,
What's the boot disk model?
Hello,
The boot disk model is :
KINGSTON SNV2S4000G : 4000,7 GB
Hello,
I didn' try to erase the disk and do a fresh install
I try on this disk (erase and fresh install)
SAMSUNG MZVLQ512HBLU-00B00 : 512,1 GB
but there is the same error.
I have tried with an USB HDD and it is the same
Hello,
Attach the EFI to check!
Here it is
delta385852
