I applied a root patch to my Tahoe for my Broadcom card, but the iPhone Hotspot isn't working.
Berkan Osman
Asus vivobook 15 x513ma
AMD ryzen 5 5500U
Amd radeon vega 7
My Wi-Fi card is a BCM4352, and yesterday I rooted hackintosh system using oclp 3.0.0 nightly. The iPhone recognizes the hotspot but can't connect to it. It connects to other networks without any problems. System macOS 26.1.
Check Security settings. Attach EFI to check
Reactions: Berkan Osman
My EFI.
Where is my problem?
Remove all deviceproperties except the layout id
Disable DummyPowerManagement
Uncheck CustomSMBIOSGuid
Set UpdateSMBIOSMode to Create
Use either AMFIPass.kext or amfi=0x80. Not both.
Why are you using HoRNDIS.kext?
gopon_user
