After upgrade from Sonoma to Sequoia I have some USB "microfreeze"
JMB13
Premium Member
Asus tuf gaming Z790-Plus wifi D4
i913900K
RX6800XT
Hello,
I had a perfectly working workstation on Sonoma, but I had tu upfate to Sequoia for software compatibility (Photoshop 2026 needs Sequioa to have full features). Update went perfectly fine. I updated all kexts, including USBToolBox.kext but I didn't create a new USB map under windows, after upgrading to OC 1.0.5. But since I notice some microfreezes in the mouse cursor motion, seems tucked for a fraction of a second and then goes well again.
Hello,
Mapping shouldn't be needed unless you're upgrading to Tahoe. Attach your EFI to check.
Switch to SSDT-AWAC-DISABLE.aml
Set ResizeAppleGpuBars to -1 and disable Resize BAR in BIOS.
Did you run OCLP yet?
Attach IOReg+MaciASL>File>Export Tableset.
copperbarg
