Unable to fully disable AMD dGPU (R9 M370X) on MacBookPro11,5 using OpenCore Sequoia 15.7.1
Nismo350z
MSI Z87-G45 GAMING
Intel i7-4770K
RS 580 2048sp flashed to RX 570
Hi everyone,
I have a MacBook Pro 15" Mid-2015 (MacBookPro11,5) with AMD Radeon R9 M370X and Intel Iris Pro.
I’m trying to completely disable the AMD GPU and use only the Intel one.
My GPU gives me wrong colors and flickering on integrated no problem.
System info
  • Model: MacBookPro11,5
    CPU: Intel Core i7 2.5 GHz (Haswell)
    iGPU: Intel Iris Pro 5200
    dGPU: AMD Radeon R9 M370X (2 GB)
    RAM: 16 GB
    macOS: Sequoia 15.7.1 (OpenCore Legacy Patcher 2.3.2)
What I did
Added boot argument:
-wegnoegpu
(checked in OpenCore Configurator → NVRAM → boot-args)
Ran:
sudo pmset -a gpuswitch 0
Tried creating a LaunchDaemon (com.intelonly.gpu.plist) to force iGPU only at startup.
Reset NVRAM and SMC.
Re-installed OCLP post-install root patches.
Problem
Even after that, both GPUs still show up:
system_profiler SPDisplaysDataType
Intel Iris Pro:
Type: GPU
Bus: Built-In
VRAM (Dynamic, Max): 1536 MB
Automatic Graphics Switching: Supported
AMD Radeon R9 M370X:
Type: GPU
Bus: PCIe
VRAM (Total): 2 GB
Hi everyone,
System info
    RAM: 16 GB
What I did
-wegnoegpu
Ran:
Problem
Intel Iris Pro:
Type: GPU
Bus: Built-In
Type: GPU
Bus: PCIe
VRAM (Total): 2 GB
nvram fa4ce28d-b62f-4c99-9cc3-6815686e30f9:gpu-power-prefs=%01%00%00%00
csrutil disable
reboot
Reactions: Nismo350z
csrutil disable
reboot
I think I got it to work, thank you for the tip!
iamgosha98
