Sequoia on AMD Ryzen 5 5600G A520M K V2 motherboard
skjaiswal
dell inspiron 15r
i5
2GB
15.x
Hi
I have created the EFI for AMD desktop (System - AMD Ryzen 5 5600G with A520M K V2 motherboard) by using your guide
and aslo made required changes in BIOS.
During booting stage it stuck during start (screen shot attached) along with EFI folder.
Pls help me to boot Sequoia on this PC and suggest any changes required for further post installation.
Thanks in advance!
  • EFI.zip
    EFI.zip
Hi
Thanks in advance!
What macOS version are you trying to boot?
Have you adjusted the BIOS settings?
I am trying to Boot and install Macos Tahoe 26 and following BIOS setting I have adjusted:
1. Secure Boot - Disable
2. SATA mode - AHCI
3. Above 4G decoding - Enable
4.CSM - Disable
5. IGD - Enable
6. Re-Size Bar support- Disable
Please review EFI and suggest any corrections.
Thank you
2. SATA mode - AHCI
4.CSM - Disable
5. IGD - Enable
Thank you
Is the BIOS up to date?
leha_m1986
