Hello everybody
koolook
asus p8p67 rev 3.1
i7 2600k
gtx 770
10.13.x
Hello, i am not beginner but i still learning, i start my hackintosh with i7 2600K, gtx 710 asus motherboard. Finaly i have gigabyte Z370 Hd3p, i make a big mistake, i update bios. so i can't access on my mac os 15.7. Find any solution.
Hello and Welcome to EliteMacx86!
You'll have to reset BIOS and then adjust the BIOS and you should be able to boot.
Thanks for your reply, I will try this but i think the last update, gigabyte can not downgrade bios. I will check. Thanks a lot
You just need to change the BIOS Settings and you should be able to boot.
leha_m1986
