Hello Everyone
jancoekx
MSI B450 Tomahawk Max
AMD Ryzen 5 3600
MSI GTX 1070 8GB
Hi, im new to a hackintosh. Im willing to have one to my setup with dual boot.
My spec is, Ryzen 5 3600, MSI B450 Tomahawk Max, 16gb ram, and MSI GTX 1070 8gb.
Can anyone guide me, please...
Hello and Welcome to EliteMacx86!
Firstly, you need to ensure your hardware is compatible. If you determine that the hardware is compatible, you can go ahead. If not, you'll have to change the hardware in order to perform the installation. In your case, GTX 1070 isn't compatible but you can patch it and have limited support or you can also upgrade the GPU to an AMD one.
Next, you gotta start building the EFI. Start here:
Then, just use a Flash Drive, create a recovery drive and perform the installation!
limited support you mean limited performance ?
Limited support here means you cannot have all the Graphics function such as metal.
balaramanim
