Random reboots while loading the system
lopess
Premium Member
MSI MEG Z590 ACE GOLD EDITION LGA 1200
Intel 11900K
MSI Radeon RX 6900 XT GAMING X TRIO
15.x
I've been trying to install MacOS on the following configuration for several days: MSI MEG Z590 ACE GOLDEDITION + 11900K + MSI RX6900XT TRIO. Unfortunately, the system doesn't always load correctly. In fact, it loads only occasionally. When it does load, everything works fine without any problems. Attached are the boot logs. Do you see anything alarming in these logs that might be causing the boot issue?
The EFI is not as per the guide and therefore problems are expected.
what is wrong with my EFI?
More specifically? I think I tried to do everything correctly. All kexts are the latest available versions. The Opencore version is also the latest. I created the ACPI files according to the recommendations. I also tried to include all the recommended settings. Unfortunately, I don't have the knowledge to identify the problem from the log files, so I'm asking for help. If you see anything incorrect, please point it out to me.
There are so many different guides on this forum that I don't know which one I'm following wrong. All the settings I've tried were from this forum. I used this guide, among others, because the configuration is very similar:
https://elitemacx86.com/threads/msi...rx-5700xt-wifi-bt-thunderbolt-4-opencore.700/
Here are a few issues:
- ACPI files are not loading in sorted order.
- Renames are depreciated and handled by Lilu, WEG and AppleALC itself.
- FadtEnableReset and ResetLogoStatus shouldn't be needed for your hardware.
- EnableWriteUnprotector shouldn't be needed for your hardware.
- ResizeAppleGpuBars must be set to -1.
- Remove all the Device properties
- Kexts are not loading in sorted order. Important kexts should load first.
- CustomSMBIOSGuid shouldn't be needed for your hardware.
- NootRX shouldn't be used as 6900XT works OOTB.
- SetApfsTrimTimeout must be set to default.
- HibernateSkipsPicker and PollAppleHotkeys shouldn't be needed as well.
- Do you really need the Ntfs and Ext drivers?
My card didn't work properly with WhateverGreen (I guess it depends on the NAVI version). It wasn't recognized at all. With NootRX, it's recognized and works fine. I need Ntfs and Ext drivers because I also use NTFS and EXT4 drives. I will take a look at the rest of the settings according to what you wrote. Thx.
What's the original Device ID?
GPU Details
Roberto Sales
