You're using a CFL ig-platform-id. Ensure the following:View attachment 9687
Here is exact settings as suggested above... and as I said with a screenshot above... doesnt boot with these settings. I removed -igfxvesa
But now instead of being stuck on the text it goes to black screen and monitor turns off.
- DVMT set to 64MB in BIOS
- ig-platform-id to 00001259
- stolenmem shouldn't be required in your case when you set the DVMT in BIOS.
- Remove -igfxvesa boot arg.
If you get a black screen, then you need to patch connectors accordingly.
