What you are trying to do is gonna require some configurations from you and your ging to need to read a lil bit brother, and if you can get the AMD Ryzen up and running then thats the first hurdle. Because then there maybe a host of applications that just wont work like they are supossed to. Had a similar experience with Aryzen 7 4700U hp probook. I used the "Chef Kiss" Amd install Guide which is what you need to check out. NootedRed from my experience isnt that stable and your black screen could be a number of different reasons for that. I used the SM BIOS MacBookPro16,3 i think it was and that was the one i got to work, And then came all the other problems. So for mine it wasnt stable enough for my liking to where i could use it . Your experience may be different. But try that "chf Kiss" AMD Install Guide. That should be a good starting point. And also for ryzen you can use the Open Core AMD Desktop Configurtion guide as well. But there are specifc kexts that are on the "chef Kiss " AMD Install site that you will probaly need that are not on dortania. So theres two references for you to try. Your hackintosh no matter what kind your trying o use its only gonna be as good as you make it to be!Theres many many levels to this,
You have to install,
2)USB Port Mapping - very critical IF you want Bluetooth to work and if You wanna Have any USB3 .So you have to do that. You can use a tool like USBMAP or You can write out the map yourself manually using te "TUPC - TPLD" USB2 and "GUPC - GPLD" USB3 Along with the follow up methods _UPC and _PLD whuch will tell your Ports what to , what kind they are etc
Method (GPLD, 2, Serialized)
Name (PCKG, Package (0x01)
Buffer (0x10) {}
CreateField (DerefOf (PCKG [Zero]), Zero, 0x07, REV) REV = One
CreateField (DerefOf (PCKG [Zero]), 0x40, One, VISI) VISI = Arg0
CreateField (DerefOf (PCKG [Zero]), 0x57, 0x08, GPOS) GPOS = Arg1 PCKG [Zero] = Arg0 PCKG [One] = Arg1 Return (PCKG) /* \_SB_.PCI0.XHC1.RHUB.GPLD.PCKG */ }
Does That look confusing Of course It does Incase you experienced with that type of thing and you will gain that experience by reading and then asking for help,and hopefully someone will have te time to help you. You want it bad enough go get it cause at the end of it its really worth all the effort.
