Your EFI is not as per the guide.Done, sorry about that
Why have you two AWAC? That's not the right thing. Use the latter one (SSDT-AWAC-DISABLE.aml).
Secondly, the same pattern can be seen with SSDT-EC and SSDT-EC-USBX. Use the latter one.
RTCMemoryFixup shouldn't be required for your hardware.
When you have the USB mapped, what's the reason to use three different ways? First you have the SSDT method, then you have the USBMap.kext and then also USBInjectAll.kext.
Your board has Intel I225-V but not sure why are you using IntelSnowMausi and IntelMausi.kext. Then, you also have AppleIntelI210Ethernet.kext. Are you using the kexts blindly? Seems like. Not a good thing. Problems are expected.
Also, the ResetNvramEntry.efi should not be in the EFI/OC directory. The correct location is in Drivers.
