GUIDE How to Enable AMD Radeon RX 6700, RX 6700 XT, RX 6750, RX 6500 XT and RX 6400
Done, sorry about that
Why have you two AWAC? That's not the right thing. Use the latter one (SSDT-AWAC-DISABLE.aml).
Secondly, the same pattern can be seen with SSDT-EC and SSDT-EC-USBX. Use the latter one.
RTCMemoryFixup shouldn't be required for your hardware.
When you have the USB mapped, what's the reason to use three different ways? First you have the SSDT method, then you have the USBMap.kext and then also USBInjectAll.kext.
Your board has Intel I225-V but not sure why are you using IntelSnowMausi and IntelMausi.kext. Then, you also have AppleIntelI210Ethernet.kext. Are you using the kexts blindly? Seems like. Not a good thing. Problems are expected.
Also, the ResetNvramEntry.efi should not be in the EFI/OC directory. The correct location is in Drivers.
Thank you for your advice, iam new on create hackintosh opencore setting. i'll try it again. thank you for helping :)
Hi, I have created a new OpenCore setup. When I use WhateverGreen.kext, it boots successfully. However, after switching to NootRX.kext, the system gets stuck at 'Couldn't alloc class "AppleKeyStoreTest"' (as shown in the screenshot attached).
Here is my new EFI setup: [link] (this is before switching to NootRX.kext).
Thank you for your help!
Your EFI isn't as per the guide.
Why are you using SSDT-PLUG and SSDT-PLUG-ALT? Use the latter one only.
You also need to enable the SetupVirtualMap
There is no reason to use CryptexFixup on your hardware. Your CPU is AVX capable.
Is your NVMe unsupported? What's the model? If its not unsupported, then there is no reason to use nvme=-1 boot arg.
Boma config sur mon profils
Bonjour ! J'ai un rx 6700 xt (nootrx) et un ryzen 5 5600 sonoma ryzentosh. Dans geekbench, le banc OpenCL affiche un score de 21k, mais il est normal que mon GPU ait un score d'environ 83k. Qu'est-ce qui pourrait ne pas aller ? (l'accélération matérielle fonctionne) S'il vous plaît, aidez-moi
PS Pour ceux qui sont confrontés à un tel problème, dans la catégorie OpenCore Kernel/Patch, désactivez le patch algrey et activez le patch Shaneee (il risque de ne pas fonctionner avec les cartes graphiques nvidia)
Bonjour tu peut me donner ton EFI stp car moi j'arrive pas
Bonjour du quelqu'un pourai médaille pour mon EFI
B de ram et rx 6700 xt
Hey! Any news on Navi 24 support? Just to know.
R00TEAD0
