SOLVED ryzen 5 5600 opencore startimage failed error
ionchad
i boot from usb i select install macos sequoia and i get error ocb startimage failed aborted and get a prohibited sign im trying to get latest version of macos sequoia im following this tutorial:
specs: ryzen 5 5600, gpu 1050 ti, msi a520m a pro motherboard
Firstly, GTX 1050Ti isn't supported natively. You can root patch and install the experimental driver.
Secondly, the EFI is not as per the guide.
thats what im trying to do, but is the efi not as the guide cause i also followed this tutorial to do the efi, im sorry this is my first time doing this
Well, that doesn't looks like. Why are you using ResetLogoStatus?
Why are you using FixupAppleEfiImages?
SecureBootModel isn't disabled which is a requirement now.
oh, ok should i disable all of this?
Review the guide and then it shows what you need to do to match your configuration.
i fixed it, nevermind
xxxxxxxxxx
