Not able to enable Nextron Amd rx580 graphic card in hackintosh.
SameerK
Gigabyte 10th generation
Intel(R) Core(TM) i3-10100F CPU @ 3.60GHz
Nextron amd Rx 580 OC 2048SP
15.x
  1. iMac Pro
Here are my spces...
Gigabyte H410M S2 V2 ATX Motherboard
Nextron Amd RX 580 OC 2048 SP GPU
Kingston 16GB DDR4-3200 RAM
EVM 240GB SSD
I am not able to enable graphic card in my hackintosh system. Someone please help, How can I enable it with Sequoia OS.?
EVM 240GB SSD
2048SP isn't supported natively and you'll have to cross flash another VBIOS.
May I know please which Graphic card is suitable for hackintosh. Or with which VBIOS do I cross flash.?
You can find the compatibility list here.
You can cross flash with RX570 probably.
alvarg82
