Preboot error on my laptop.
EFI folder.
Disable ProtectMemoryRegions
Disable NootedRed.kext
Replace AMDTscSync with ForgedInvariant.kext
Disable ThirdPartyDrives and then check.
Also, are you using an offline installer or online installer?
Using offline installer.
How to allocate disk for macOS without deleting Windows?
I want to install Sequoia instead of Ventura and will the settings still be valid?
rajdeep704
