Stuck at apple Logo with progress bar half 30% completed while installing MacOS Sonoma
ZeroTwo
Asus ROG Strix G15 2021
AMD Ryzen 9 5900HX
RTX 3060 Laptop GPU
  2. OpenCore (Legacy)
  1. Other
Asus ROG Strix G513QM 2021 Specs:-
Processor-AMD Ryzen 9 5900HX 3.30Ghz
RAM-16GB DDR4
WIFI- Intel wifi 6e
GPU-RTX 3060 Laptop GPU 6GB
i got an efi somehow from internet of a laptop name razerblade which has same specs as my laptop and the efi worked till it gets stuck at the apple logo with progress bar 30% completed
please help me and tell me what should i repair in order to install sonoma in my pc i am also thinking of Sequoia please tell me the additional files for efi for sequoia also i am sharing the EFI here help me EliteMacX team.
RAM-16GB DDR4
WIFI- Intel wifi 6e
No EFI attached.
No EFI attached.
due to large file size it was not uploaded but i can send you the drive link please download that efi file and check it out and tell me what should i do to fix this
in addition what upgrades should i make to run sequoia also my pc is compatible with it moreover i am totally new to this thing so please help me with proper details
‼️link to the EFI i used in my laptop
Your EFI configuration is not as per the guide and problems are expected due to that.
Regarding upgrades, as its a Laptop, there's not much you can upgrade without hassle. The basic are the RAM and storage (SSD).
Also, what's the boot disk model?
i am using sandisk usb to boot the installer and installing macos in my second ssd Samsung 970 evo
That could be one of the potential cause. Samsung drives are known for their problems on macOS. Do you have any spare drive to test?
in my laptop both ssd is of samsung but i didnt install maos in it cuz whenever i try to install the macos it just get stuck with the apple logo and a progress bar in it and i am using Sandisk as my macos boot load setup
Why are you quoting irrelevant post?
felipepedrosa
