Intel uhd 630: i5 10500 7mb vram (comet-lake)
Nikitos
ASUS PRIME H510M-A
Intel Core i5 10500
Intel UHD Graphics 630
Hi, I need help with my intel uhd 630 graphics which works in desktop as mobile graphics (without dGpu)
OS: Sonoma
CPU: Intel Core i5 10500
IGPU: intel uhd 630 (comet-lake)
RAM: 32 gb
Screen Resolution: 1920 x 1080
cable for screen: HDMI
Bootloader: Opencore
I have already installed the OS Sanoma. The Internet works via cable for now, I will add a WiFi module later. The sound works only via 3.5 jack, and via HDMI it does not work yet. All USB ports work. I need to configure the graphics to support 3D
Just to ensure, is the GPU working with Full QE/CI? The title says you have 7MB VRAM whereas, the thread description says you have got it working but as mobile graphics.
My graphics work, but without acceleration. I want I need 3D support, like on Mac Mini (without discrete graphics card)
That's a misleading explanation.
Attach your BIOS Settings and EFI you're using to boot. Also, what's your monitor resolution?
OS: Sonoma
RAM: 32 gb
efi which i use to boot os is attached to my 1st message
Remove -igfxvesa from boot args and patch the framebuffer correctly. Ensure that the DVMT is set to 64MB in BIOS.
The screenshot shows that the system identifies the processor device-id correctly 0x9BC8
but there is no graphics acceleration
  • config.plist
    config.plist
That's weird. The kext isn't loaded. That means the acceleration is disabled somehow. Attach a copy of EFI and IOReg to check further.
kocsik
