problem with BCM4352 802.11ac Wireless and bluetooth on sequoia 15.3.2
naiden
b650
R9 7900X
RTX 4060 and iGPU radeon
15.x
I can't get BCM4352 802.11ac Wireless and Bluetooth to work on Sequoia 15.3.2. I'm using the following kexts:
amfipass.kext
IOSkywalkFamily.kext
IO80211FamilyLegacy.kext
bluetoolfixup.kext.
im appling root patch of OCLP, reset nvram and patching DMAR Table boot but no effect
EFI folder link: https://drive.google.com/file/d/1pp1MHyYVlzgo7lGv0Sx3klJHM2MUY-mt/view?usp=drive_link
View attachment 9237View attachment 9238
Add AirPortBrcmFixup. Make sure to inject only the AirPortBrcmNIC and not the 360injector kext.
Also, you should mention your hardware specs. The hardware in your profile indicates an AMD hardware and the EFI and screenshots you attached shows Intel.
Reactions: naiden
yes i remapped usb ports under windows 11 and bluetooth started working :)
Good to hear. As the issue is resolved, marking SOLVED and closing this thread!
xxxxxxxxxx
