OSX 10.9 on modern hardware?
Demian-mac
AMD Radeon
AMD Ryzen 7 47000U
Maibook M
Hi! You once helped me with MacOS on my laptop. Now hell has come for this laptop........... Can you help me assemble an EFI for my laptop SPECIFICALLY FOR OSX 0.9? The characteristics are the same. Maybe it needs FakeCPUID? I don't know at all, since I assembled the EFI a long time ago. Can you help me?
Well, are you sure you want to use OS X 10.9. That's Mavericks and almost everything will there will NOT work due to expired certificates and what. Is there any specific reason to install Mavericks?
I just want to install it, and certificates can be easily bypassed by changing the date
Its not about just the installation. For example, Safari will NOT work, most of the Apps will simply not work there.
I just want to experiment, it's not serious. I understand everything, I just want to achieve a result.
CPU: AMD Ryzen 7 4700U
RAM:24GB
Graphics: AMD Radeon embedded
Motherboard: Quanta MaiBook M
Disk: 256GB
RAM:24GB
Disk: 256GB
Will not work. NootedRed requires macOS at least 10.15 to work!
Are there any analogues, or is it possible to do without it?
No, the AMD OS X patches isn't available for OS X10.9. Maybe you can try patched Kernel.
kocsik
