Hmm Did the following patches my monitor shows black screen
Yes, its common since 9th Gen. You'll also have to do Bus ID patching to prevent black screen on HDMI.
@BLINGVOLDER
You not add DeviceProperties about iGPU intel video.
@BLINGVOLDER
Add the following Device properties keys and values:
AAPL,ig-platform-id:07009B3E
enable-hdmi-dividers-fix:01000000
enable-hdmi20:01000000
enable-max-pixel-clock-override:01000000
framebuffer-con0-busid:01000000
framebuffer-con0-enable:01000000
framebuffer-con0-pipe:12000000
framebuffer-con0-type:00080000
framebuffer-con1-busid:02000000
framebuffer-con1-enable:01000000
framebuffer-con1-pipe:12000000
framebuffer-con1-type:00040000
framebuffer-patch-enable:01000000
hda-gfx: onboard-1
Also, add agdpmod=vit9696 in boot args. In addition, set the DVMT as 64MB in BIOS.
Save the config.plist and attach it here to check.
Reactions: Max.1974
@BLINGVOLDER
hda-gfx: onboard-1
Here is the EFI With the device properties (still black screen)
xmax114
