The framebuffer is not patched correctly as mentioned above. You must define the other properties as well.
Are you able to boot the system with proper graphics?
I dont have the AppleIntelFramebuffer@X node on the IO registry what should i do?
That is because the IGPU is still disabled via bootargs. You were already told to remove it.
mrdarkd
