The Prohibited symbol is gone but I am stuck at booting the OS
Did you make the required changes in your config.plist as indicated in the post #8? If so, attach the EFI to check!
Not sure what's wrong. All you were supposed to make the required changes in your "previous" config.plist as outlined in the post #8. Is there any difficulties in understanding the outlines? The EFI you attached is completely bogus!
What do you mean by bogus? This EFI was made from the video that you sent me earlier.
I was able to load macOS Because I forget to add the "debug=0x100" on the boot args but yeah still no graphics acceleration
No, it is clearly not. There are different settings, different set of kexts which was not demonstrated in the guide. The previous EFI you attached, was according to the guide, but a few changes were required as you probably missed it.
Unless you do what's being asked to, won't be able to help. All you had to do is make the required changes as outlined in the post #8, in your previous EFI. Instead of doing that, you're attaching a different EFI than that and worried why the system still has problems!
But I did these changes that are mentioned in post #8 yet still no acceleration!
NO, THOSE CHANGES DOES NOT REFLECT IN THE CONFIG.PLIST YOU ATTACHED. Either you never made those changes or attached a wrong config.plist. Double check and attach the correct one.
Here's the EFI file
alvarg82
