How to Fix Broadcom WiFi on macOS Sonoma and Later
This guide covers fixing Broadcom WiFi on macOS Sonoma and Later using Clover and OpenCore. By following this guide, you'll be able to enable Broadcom based WiFi on macOS Sonoma and Later using Clover or OpenCore Bootloader. This guide is solely for OpenCore users and may not work with Clover as it has no option to block the kexts permanently other than manually which is done from the Clover GUI picker. This guide will be updated in the future if Clover gets such a feature.
This guide must be followed on macOS Sonoma and later only. If you're running a prior version of macOS, there is the original Broadcom WiFi and Bluetooth guide that works up to macOS Ventura:
Please note that for Bluetooth, the existing guide will serve on macOS Sonoma as well.
Recently, Apple announced their new macOS lineup i.e. macOS Sonoma on June 06, 2023, and publically released the final version this fall i.e. on September 26, 2023. Unfortunately, with the announcement of macOS Sonoma, Apple has officially dropped support up to Skylake, including IGPU support, followed by macOS Ventura. However, the biggest downfall we see is the removal of Broadcom WiFi support in macOS Sonoma. This has led to a major disappointment with the users who use non-Apple computers with macOS installed.
If you're not new and familiar with non-Apple computers running macOS, you might already know that on non-Apple computers, Broadcom WiFi is generally preferred for a native WiFi/BT function (such as Fenvi T919, BCM94360NG, BCM94352Z, etc). However, since the release of macOS Sonoma, Apple has removed support for all unsoldered Broadcom WiFi so if you have any of such models, the WiFi will not work as of now. If you check S/L/E, you'll notice that the support for older Broadcom based WiFi Cards are absolutely absent and all the related kexts are removed from the respective directory. This means even if you install a native WiFi Card (such as Fenvi T919 or BCM94360NG), the WiFi will still not work due to the lack of required drivers. Third-party WiFi such as Intel will continue to work with third-party kexts. In addition, the USB based WiFi having Realtek/MediaTek chipsets will also work with the supplied drivers from its manufacturer. However, there is still a workaround to get those cards working on macOS Sonoma, thanks to the OCLP team for their continued support for the legacy hardware.
Apple started to give hints from Monterey, where AirPortBrcmNIC was moved to a new location as a plugin, and a new kext IO80211FamilyLegacy.kext was introduced. To support the other latest WiFi models, a new kext AppleBCMWLANBusInterfacePCIeMac.kext was introduced since macOS Ventura and fast forward to macOS Sonoma, the IO80211FamilyLegacy.kext has been completely removed and no longer exists. This clearly tells us that Apple already planned to make the old models obsolete and remove the support in future releases due to their major shift from Intel to their own Apple Silicon based Mac lineups. This is not the first time Apple has done such. This practice is common with Apple and you would have probably known if you're an Apple enthusiast.
You might have a question that generally Apple has been using Broadcom WiFi in their Mac models since a long time
so does this means native supported Mac models which has support for macOS Sonoma, will lack the WiFi function? Well, the answer is no. That's because
Thus, leaving the WiFi/BT card in an unusable/non-working state.
Screenshot 2023-10-05 at 9.07.50 AM-min.png Screenshot 2023-10-05 at 9.07.37 AM-min.png
Neither it is available in the Menu bar.
Screenshot 2023-10-05 at 9.59.32 AM-min.png Screen Shot 2023-10-05 at 10.58.11 PM-min.png
Following are the requirements for enabling Broadcom WiFi on macOS. Please ensure you meet the requirements before proceeding with this guide.
WiFi/ BT Hardware
  • OS X Yosemite and Later (Pre-installed).
  • Lilu
  • IOSkywalkFamily
  • IO80211FamilyLegacy
  • AirPortBrcmFixup
  • corecaptureElCap
  • IO80211ElCap
  • OpenCore Legacy Ptcher (OCLP) v1.0.1 or Later
  • IOReg
If you're attempting a clean install or an upgrade, it is highly recommended to perform a clean install or the upgrade first before you follow this guide.
The very first step is to set up BIOS to have the Broadcom WiFi/BT enabled on your system. This is because there are a few systems that have the option to Enable WiFi/BT in BIOS which affects the functionality under macOS/OS X.
STEP 2: Verify the WiFi Detection
The next step is to verify whether the installed card is being detected under macOS or not. This step is required in order to ensure you're on the right track and you have the right card as per the compatibility list. If the Card is not detected, even following the guide correctly will not help to get it recognized. In addition, not all WWN slots are M.2. There are a few systems with cNVi slots, where even if you replace the card with a compatible one, the card will not be detected at all. This is because of the proprietary connectivity interface by Intel. This means the particular CNVi slot on the motherboard will accept only Intel-based WiFi/BT Cards therefore if you replace the card, you must verify the detection of the WiFi/BT module. To verify the WiFi/BT detection, follow the steps below.
1. Download Hackintool from the Download section.
3. Locate your WiFi module under the PCIe section in Hackintool. The WiFi module is usually listed as a Network Controller under the Class and Subclass column.
STEP 3: Add Required Kexts
The next step is to install the required kexts in order to enable WiFi and Bluetooth support. Depending on your Card type, choose one from below.
I. Apple Airport and Fenvi Cards
To enable the WiFi support, you'll need to add IOSkywalkFamily.kext and IO80211FamilyLegacy.kext along with the child kext AirPortBrcmNIC.kext. These two kexts are needed together to work in conjunction in order to enable the WiFi for Airport and Fenvi based cards.
1. Download IOSkywalkFamily.kext and IO80211FamilyLegacy.kext.
3. Copy IOSkywalkFamily.kext and IO80211FamilyLegacy.kext to EFI/OC/Kexts directory.
4. Open your config.plist and add IOSkywalkFamily.kext and IO80211FamilyLegacy.kext entries in the Kernel>Add section of your config.plist. In addition, you'll need to specify the MinKernel to 23.0.0 to ensure that the kext only loads on macOS Sonoma.
NOTE: Your kext list and entries may differ as each system is different and will have different requirements.
II. Non-Apple AirPort and Non-Fenvi Cards
With the injection of IOSkywalker.kext+IO80211FamilyLegacy.kext (consists of AirPortBrcmNIC.kext) and patching with OCLP (later in the guide), the native cards will work (such as Fenvi T919, BCM94360NG, etc). However, if you have a card that does not have any of these matching IDs (14E4:43ba, 14e4:43a3, or 14e4:43a0), such as BCM94352Z, you'll also need to inject AirPortBrcmFixup.kext in order to drive them. It's no wonder that despite these cards being supported, they do not work OOTB and have always required AirPortBrcmFixup.kext and the related kexts for Bluetooth to work! This is because mostly these Cards are non-Apple manufactured cards. This step is only required for Non-Apple Airport and Non-Fenvi Cards i.e. cards that do not work OOTB in macOS Ventura or prior (such as BCM94352Z). Skip this step if you have an Apple AirPort and Fenvi Card with a Device ID (14E4:43ba, 14e4:43a3, or 14e4:43a0).
1. Download IOSkywalkFamily.kext, IO80211FamilyLegacy.kext and AirPortBrcmFixup.kext.
3. Copy IOSkywalkFamily.kext, IO80211FamilyLegacy.kext and AirPortBrcmFixup.kext to EFI/OC/Kexts directory.
4. Open your config.plist and add IOSkywalkFamily.kext, IO80211FamilyLegacy.kext, and AirPortBrcmFixup.kext entries in the Kernel>Add section of your config.plist. In addition, you'll need to specify the MinKernel and MaxKernel as shown below to ensure that the kext only loads on the appropriate version of macOS, if using the same EFI for booting multiple macOS versions.
5. You'll have to prevent AirPortBrcm4360_Injector.kext from loading. This can be achieved either by (i) removing the kext entry to keep the config.plist more tidy or (ii) using the boot arg to load only one specific driver or (iii) via the Device Properties or (iv) DSDT/SSDT patch or (v) by specifying the MinKernel and MaxKernel.
  • Please ensure the kexts are loading in the correct sorting order.
  • If the kext is already present in the directory, replace it with a new version
  • Do not use AirportBrcmFixup.kext.dSYM
III. Legacy Cards
Despite these Legacy Cards being supported previously at one time, the support has been removed since Sierra for the Broadcom 43224 and Broadcom 4331 since Mojave. To enable the WiFi support for these legacy cards (BCM4331 and BCM43224), you'll need to add corecaptureElCap.kext and IO80211ElCap.kext along with the child kexts (AirPortBrcm4331.kext and AirPortBrcm43224.kext). These two kexts are needed together to work in conjunction in order to enable the WiFi for legacy cards.
1. Download corecaptureElCap.kext and IO80211ElCap.kext.
3. Copy corecaptureElCap.kext and IO80211ElCap.kext to EFI/OC/Kexts directory.
4. Open your config.plist and add corecaptureElCap.kext and IO80211ElCap.kext entries in the Kernel>Add section of your config.plist. As this guide is for Broadcom only, you'll need to remove the AirPortAtheros40.kext entry as shown below. In addition, you'll need to specify the MinKernel as shown below to ensure that the kext only loads on the appropriate version of macOS, if using the same EFI for booting multiple macOS versions. You can also use one of the kext as per your card and remove the irrelevant ones to keep the config.plist more tidy (later in the guide).
Depending on the card you have e.g. Broadcom 4331, you can keep the AirPortBrcm4331.kext and remove the AirPortBrcm43224.kext to keep the config.plist more tidy.
Depending on the card you have e.g. Broadcom 43224, you can keep the AirPortBrcm43224.kext and remove the AirPortBrcm4331.kext to keep the config.plist more tidy.
STEP 4: Block Required Kexts
The next step is to block the IOSkywalk.kext. This step is required for Modern WiFi only regardless of the Apple AirPort and Fenvi or Non-AirPort and Non-Fenvi cards. If you have a legacy card, you can skip this step. Bocking the IOSkywalkFamily.kext in macOS Sonoma will allow us to manually inject a previous version of IOSkywalkFamily.kext, therefore allowing us to downgrade. This is required because, unless you don't block this kext, you'll not be able to inject the prior version of IOSkywalkFamily.kext, and while the previous version of IOSkywalkFamily.kext is injected with no blocking, it will throw an error when booting from the system drive. To block the IOSkywalk.kext, follow the steps below.
1. Assuming the config.plist is still open, add the following under Kernel>Block section of your config.plist. In addition, you'll need to specify the MinKernel to 23.0.0 to ensure that the kext is only blocked on macOS Sonoma.
ArchIdentifier*CommentMinKernelMaxKernelMaxKernelStrategyEnabled
Anycom.apple.iokit.IOSkywalkFamilyAllow IOSkywalkFamily Downgrade23.0.0ExcludeYES
NOTE: If you're using a USB Ethernet Adapter that utilizes the ECM Protocol, you'll have to add ECM-Override.kext to prevent Kernel Panic as Apple's DriverKit stack uses IOSkywalk for ECM Adapters.
STEP 5: Disable the Secure Boot Model
Once you have blocked the IOSkywalk.kext, the next step is to disable the Secure Boot Model. To disable the Secure Boot Model, follow the steps below
1. Assuming the config.plist is still open, set the SecureBootModel to Disabled under the Misc>Security section of your config.plist
NOTE: Once you're done with the root patching and the WiFi is enabled, you can set the SecureBootModel to Default again.
STEP 6: Add Boot Args
Once you have disabled the Secure Boot Model, the next step is to add the required boot args. To add the boot args, follow the steps below
1. Assuming the config.plist is still open, add amfi=0x80 to the boot-args key under the 7C436110-AB2A-4BBB-A880-FE41995C9F82 UUID list in the NVRAM section of your config.plist.
QUICK INFO: When using amfi=0x80 boot arg, certain applications may not respond and eventually crash such as Firefox as reported by @svan71.
STEP 7: Disable System Integrity Protection (SIP)
Once you have added the required boot args, the next step is to disable the System Integrity Protection. To disable the SIP, follow the steps below.
1. Assuming the config.plist is still open, set the csr-active-config to 03080000 as the DATA value for root patching.
2. Save your config.plist.
STEP 8: Boot using the new Configuration
once you boot with the new configuration, the system will how that the wifi is enabled as the required kexts are injected. However, you won't be able to find and/or connect to any network.
Screenshot 2023-10-05 at 9.19.08 AM-min.png Screenshot 2023-10-05 at 9.19.28 AM-min.png
Neither the WiFi Networks are available from the Menubar
If you check the IOReg, you'll find that neither the AirPort_BrcmNIC or the IOSkywalk Kexts are loading.
STEP 9: Patch System Volume
To patch the system using OCLP, follow the steps below.
1. Download OpenCore Legacy Patcher (OCLP) from the download section of this forum.
2. Open OCLP and you'll see something similar to the screenshot attached below.
3. Click on Post Install Root Patch and you'll see something similar to the screenshot attached below.
As you can see, the OCLP has automatically detected what patch to apply. If the SIP is enabled, you may notice a message stating "SIP is Enabled"
If you notice that, make sure to disable it as described in STEP #1.
Click on Start Root Patching and you'll need to run OCLP as root. You'll see something similar to the screenshot attached below.
Click on Yes to relaunch OCLP as root. When prompted, enter your system password. You'll see something similar to the screenshot attached below.
Screenshot 2023-10-07 at 12.33.23 PM-min.png Screenshot 2023-10-05 at 9.22.58 AM-min.png
Once the OCLP is launched as root, it will start patching the system volume.
Once OCLP finishes patching the system volume, it will prompt to reboot. Click on Reboot to restart your system.
Screenshot 2023-10-05 at 9.23.18 AM-min.png Screenshot 2023-10-07 at 12.12.42 PM-min.png
STEP 10: Restart your System
Verifying the WiFi
The next step is to verify whether the WiFi and BT are working or not. Follow the steps to verify the WiFi function.
  • Verify the WiFi Interface in About This Mac>System Report>Wi-Fi
  • Verify WiFi discoverability in System Preferences>Network
  • Verify the WiFi Interface connection with 2.4GHz and 5GHz in About This Mac>System Report>Wi-Fi
Screenshot 2023-10-07 at 2.41.30 PM-min.png Screenshot 2023-10-05 at 9.26.39 AM-min.png
  • Verify WiFi connection in System Preferences>Network
Screenshot 2023-10-05 at 9.26.54 AM-min.png Screenshot 2023-10-05 at 9.26.57 AM-min.png
  • Verify connected WiFi Networks and Other Networks
Screenshot 2023-10-05 at 9.27.02 AM-min.png Screenshot 2023-10-05 at 9.27.09 AM-min.png
  • Verify the network details such as signal strength and channel number using the Alt key.
Screenshot 2023-10-07 at 2.21.54 PM-min.png Screenshot 2023-10-05 at 10.16.05 AM-min.png
  • Verify AirPort_BrcmNIC and AirPort_Brcm43xxLLSkywalkInterface is loading in IOReg
Browser
  • Verify the speed tests for 2.4GHz and 5GHz Network
NOTE: The speed tests were performed on a test system that did not have an antenna installed and the WiFi Router was at least 3m away from the system.
Screen Shot 2023-10-09 at 2.27.10 AM-min.png Screen Shot 2023-10-09 at 2.27.55 AM-min.png
Card TypeKext ConfigurationKext Install Location
  • IOSkywalkFamily.kext
  • IO80211FamilyLegacy.kext
    • AirPortBrcmNIC.kext
  • AirPortBrcmFixup.kext
    • AirPortBrcmNIC_Injector.kext
Legacy
  • corecaptureElCap.kext
  • IO80211ElCap.kext
    • AirPortBrcm4331.kext
    • AirPortBrcm43224.kext
fw is loaded but unfortunately it doesn't work
Seems like you forgot to add the IOSkywalkFamily.kext. Add it and also enable blocking for the IOSkywalkFamily.kext. In addition, run OCLP to patch the system once again. You should have the WiFi working.
As I understand it, I should do everything according to the procedure for modern cards? I specifically gave up Fenvi, which I also have, and bought BCM4331, to be able to use the procedure for "legacy cards", i.e. not to block IOSkywalkFamily, because I have an Intell XXV710 25G card on board. When I block IOSkywalkFamily, XXV710 will not work.
Yes, that's right!
The guide will be corrected after your results as no longer having the BCM4331 card to test ;(
Umm, i think it will require 42XX cards for the Legacy cards as the modern ones are dependent on the IOSkywalkFamily and unfortunately, the Ethernet (native drivers) are also dependent on the IOSkywalkFamily and in the process to enable the BCM WiFi, the IOSkywalkFamily is downgraded and the Ethernet no longer function with the native drivers.
BTW, what's the board model you are using that has 25GbE onboard?
Maybe I expressed myself badly. It's not a card on the motherboard, but a card on the Pcie. I'm using Intel XXV710-DA2.
I confirm that BCM4331 works without a problem when installed according to the procedure for modern cards. However, it doesn't work when we want to run it as legacy cards (or I don't know how to do it).
I ordered Atheros Wireless, AR5BXB112, AR9380. I'll see if it will be possible to achieve what I want on this card.
According to the OCLP documentation, modern and legacy cards are:
  • "Modern"cards:
    • Broadcom:BCM94350 (incuding BCM94352), BCM94360, BCM43602, BCM94331, BCM943224
    • Required Kexts: IOSkywalkFamily, IO80211FamilyLegacy, AirPortBrcmNIC, AirportBrcmFixup, AirPortBrcmNIC_Injector.
  • "Legacy"cards:
    • Atheros: AR928X, AR93xx, AR242x/AR542x, AR5418, AR5416 (never used by Apple)
    • Broadcom: BCM94322, BCM94328
    • Required Kexts: corecaptureElCap, IO80211ElCap, AirPortAtheros40 (for Atheros only)
Besides patching Wifi/BT cards officially used in Apple products, OCLP also supports Wi-Fi patching of systems with 3rd party Broadcom chipsets (enabled by AirportBrcmFixup.kext) which are often found in Hackintoshes:
  • device-id pci12e4,4357 → BCM43225
  • device-id pci12e4,43B1 → BCM4352
  • device-id pci12e4,43B2 → BCM4352 (2.4 GHz).
It is also worth bearing in mind that the BCM4331 chip was used in various cards and various models of Apple hardware in various variants. Perhaps some of them are identified as "legacy" and others as "modern", depending on the "device-id". This would require further investigation.
Additionally, I also found this information regarding "modern" and "legacy" cards:
AirPort Adapters​
So what are AirPort adapters and why are they the preferred piece of hardware? Well, they're genuine Apple wireless cards pulled from MacBooks and iMacs, meaning no extra configurations/kexts are required to get this hardware up and running. The main issue is that they require an adapter to PC hardware and are generally bulkier making them unfavourable in laptops but perfect for desktops.
Best part, no kexts needed!
  • Note: When buying a Wifi card and an adapter, make sure the antenna sockets match up, there are 2 main types of sockets:
    • MHF4: Commonly used on M.2 and Apple's laptop wifi cards
    • U.FL: Commonly used on mPCIe and Apple's desktop wifi cards
Which cards shipped with what?​
Socketed cards
Ones you can buy and install yourself
  • BCM943602CDP(Wifi) + 20703A1 (Bluetooth 4.0) + U.FL Connector
    • iMac16,x
    • iMac17,1
    • iMac18,x (Different Bluetooth module, 20703A2, Bluetooth 4.2)
  • BCM94360CD (Wi-Fi) + 20702B0 (Bluetooth 4.0) + U.FL Connector
    • iMac14,x
    • iMac15,x
    • MacPro6,1
  • BCM94331CD (Wi-Fi) + BRCM20702 (05AC:828b, Bluetooth 4.0) + U.FL Connector
    • iMac13,x
  • BCM94360CS2 (Wi-Fi) + BRCM20702 (05AC:821f, Bluetooth 4.0) + MHF4 Connector
    • MacBookAir5,x
    • MacBookAir6,x
    • MacBookAir7,x
  • BCM943602CS (Wi-Fi) + 20703A1 (Bluetooth 4.0) + MHF4 Connector
    • MacBookPro12,x
  • BCM94360CS (Wi-Fi) + 20702B0 (Bluetooth 4.0) + MHF4 Connector
    • Macmini7,x
    • MacBookPro11,x
  • BCM94360CSAX + BRCM20702 (05AC:828c, Bluetooth 4.0) + MHF4 Connector
    • MacBookPro10,x
  • BCM94350 + MHF4 Connector
    • MacBook8,1 - 4350C1, Bluetooth 4.0
    • MacBookPro13,x - 20703A2, Bluetooth 4.2
    • MacBookPro14,x - 4350, Bluetooth 4.2
Legacy Wi-Fi Cards
Broadcom:
  • BCM4328
    • iMac5,1-9,1
    • MacBook3,1-4,1
    • MacBookAir1,1-2,1
  • BCM4321
    • MacPro2,1
    • Macmini4,1
  • BCM4322
    • MacBook5,1
    • MacBookPro5,1 and 7,1
    • MacBookAir3,1-5,1
    • MacPro5,1
  • BCM43224
    • MacBook6,1
    • MacBookPro6,1
  • BCM4331
    • Macmini5,x
    • MacBookPro8,x-10,x
Atheros:
  • AR242X/AR542X
    • MacBook1,1
    • Macmini1,1-2,1
  • AR5418
    • MacBook2,1
  • AR928X
    • iMac10,1-11,x
    • MacPro3,1
  • AR93XX
    • iMac12,x
Solder/proprietary cards
Apple's custom cards that no one else has, specifically called SOCs from Broadcom
  • BCM4364 (Wi-Fi) + 4364B0 (Bluetooth 5.0)
    • iMac19,x
    • Macmini8,1
    • MacBookPro15,x
    • iMacPro1,1 - 4364(Bluetooth 4.2)
    • MacPro7,1 - 4364B3(Bluetooth 5.0)
  • BCM4355
    • MacBookAir8,1
If so, you may be able to set a device-id that will allow this card to be detected as a "legacy" model.
Oh, makes sense now. Was surprised to see what consumer grade board has onboard 25GbE chip. xD
Perfect. Thank you for the confirmation. As stated previously, the guide needs to be corrected. It will not work with the legacy style as the BCM4331 still requires IOSkywalkFamily.
Atheros ain't good now. The best would be to use BCM94322 or BCM94328. If you can order these and test, will indicate the issue and maybe create a separate thread regarding the IOSkywalkFamily dependency for Ethernets. This has been indicated as a note in the Intel WiFi guide though.
Is that the case? Not 100% sure.
AirPorts do not require other kexts than the native ones. But the game has changed since Sonoma and it has really made high performance Ethernet users disappointed.
Yes, but the device itself needs to be legacy in order to work otherwise it won't.
As indicated by you, we might need to grab some info on these:
  • BCM4331
    • Macmini5,x
Once we have the device-id details, we can order a card with that device-id (research required) and then can check if it works using the Legacy procedure.
ok, I also ordered BCM94322. We will check both Broadcom and Atheros.
  • Love
Thank you. Yes, we'll check it accordingly.
I found a solution! See the pci_data.py file in OCLP.:
class broadcom_ids:
AppleBCMWLANBusInterfacePCIe = [
0x43DC, # BCM4355
0x4464, # BCM4364
0x4488, # BCM4377b
0x4425, # BCM4378 (M1)
0x4433, # BCM4387 (M1 Pro/Max/Ultra)
AirPortBrcmNIC = [
# AirPortBrcmNIC IDs
0x43BA, # BCM43602
0x43A3, # BCM4350
0x43A0, # BCM4360
# Not natively supported, but supported by AirportBrcmFixup
AirPortBrcmNICThirdParty = [
0x4357, # BCM43225
0x43B1, # BCM4352
0x43B2, # BCM4352 (2.4 GHz)
AirPortBrcm4360 = [
# AirPortBrcm4360 IDs (removed duplicates for 4360 class cards)
0x4331, # BCM94331
0x4353, # BCM943224
AirPortBrcm4331 = [
# AirPortBrcm4331 IDs (removed duplicates for 4331 class cards)
0x432B, # BCM94322
AppleAirPortBrcm43224 = [
# AppleAirPortBrcm43224 IDs
0x4311, # BCM4311 - never used by Apple
0x4312, # BCM4311 - never used by Apple
0x4313, # BCM4311 - never used by Apple
0x4318, # BCM4318 - never used by Apple
0x4319, # BCM4318 - never used by Apple
0x431A, # Unknown - never used by Apple
0x4320, # BCM4306 - never used by Apple
0x4324, # BCM4309 - never used by Apple
0x4325, # BCM4306 - never used by Apple
0x4328, # BCM4328
0x432C, # BCM4322 - never used by Apple
0x432D, # BCM4322 - never used by Apple
OCLP developers removed 4331 from legacy cards. So just change the card's device-id to 0x432B. Then it will be recognized by OCLP as "legacy". And voila wifi works on IO80211ElCap and corecaptureElCap.
  • Love
DeFastestTingAlive
