Install Sequoia on Intel Desktop
TEALC82
Aorus Z690
i7-12700k
RTX 3090
Hello,
I want to install MacOS Sequoia but the installation is blocked, I tried several times to redo my EFI folder but always the same.
EFI
Does anyone have an idea? Thank you.
Hello, I just tested OpCore-Simplify for the creation of the EFI, the installation progresses more but blocks.
I change my GPU by RX5700XT for testing
I
Hello,
EFI
Try attaching the EFI directly here. The site that you uploaded the EFI on, has time limit and access is restricted.
J.An
