In memory Panic Stackshot Succeeded ** Bytes Traced 4397
uurero
  3. Windows Phone
  4. Other
this issue not like others bc i searched and theres no solution.
my pc:
Processor AMD Ryzen 5 5600 6-Core Processor 3.50 GHz
Installed RAM 16.0 GB
MotherBoard ASRock B550 Phantom Gaming 4/ac
System type 64-bit operating system, x64-based processor
RTX 3060TI (i changed pat to Shaneee bc i know my gpu not support Algrey)
Pen and touch No pen or touch input is available for this display
im trying to install in Olarila Sonoma 14.5 on my pc by opencore and it gives me this error
i got alot of errors before this but always when i try to fix one i get another
i uploaded my config pls check my problem
and please try with me to look for issues not like others only saying my gpu not support to just shut me up
i watched your guide and i watched alot of guides
but last guide was that https://github.com/mikigal/ryzen-hackintosh
  • config.plist
    config.plist
my pc:
Seems like the kexts are outdated. Secondly, RTX isn't supported on macOS.
so should i update all kexts and it will fix it?
btw i got alot of errors before so im not wonder if i got another one when i fix this error
i will disable the gpu from mac (if i think i need to Add -wegnoigpu under Boot Arguments right?)
Not sure what's the point in running an OS that does not support acceleration. If you need a system without acceleration, better to use VMware or Virtual Box.
im having a simillar issue with Ryzen 3 5300U and iGPU
Roberto Sales
