How enable graphics acceleration on AMD iGPU Radeon 680M?
Hello.
I'm new to this, I created my EFI, I took yours from this thread and I can't get past the same point in both, (at least you have it installed). In this image that I attached is where it gets stuck, the image is not mine but the errors are the same. My PC is Beelink EQR6 with the 7735hs and the 680M.
Sorry, i don,t know about the language, Thanks.
Your APU isn't supported.
I've read something about this incompatibility but since the first message in this thread has the same processor and has installed it even though he wants to enable graphics acceleration, I continued with the installation. I'll assume that and keep looking for more later, thanks.
Installation can be done for sure but the Graphics isn't supported as of now. So, it will have almost the same lags as in Virtual Box or VMware.
J.An
