How enable graphics acceleration on AMD iGPU Radeon 680M?
jamal
ASUS
AMD Ryzen 7 7735HS with Radeon Graphics RX 680M
NVIDIA GeForce RTX 4060 Laptop GPU
i've got ventura installed following dortania's guide, but i couldn't active APU graphics acceleration with nootedred, there's any workaround that i could try? using fakeid, spoof gpu?
CPUAMD Ryzen 7 7735HS with Radeon 680M
please any ideas are welcome!
It's posible to modify for example on System/Library/Extensions/AMDframebuffer.kext "Content/info.plist" and include my igpu "device id" on there?
in attach efi used, thanks in advance!
Spoofing only works where the driver itself has actual support.
As of now, it's not supported.
Still any update for amd 680m apu? or any ETA for this?
Currently, your APU isn't supported so no wonder why it doesn't work.
To modify, rather than modifying the original kext, try to spoof via Device Properties or SSDT method. But the probability is still very low to get it working until there is some update.
Any updates if this is working right now?
Buenas. Soy nuevo con esto, he creado mi EFI, he cogido la tuya de este hilo y no consigo pasar del mismo punto en ambas, (tu al menos lo tienes instalado). En esta imagen que adjunto es donde se me queda estancado, la imágen no es mía pero los fallos son iguales. Mi pc es Beelink EQR6 con el 7735hs y el 680M. Gracias.
English only.
Hello.
I'm new to this, I created my EFI, I took yours from this thread and I can't get past the same point in both, (at least you have it installed). In this image that I attached is where it gets stuck, the image is not mine but the errors are the same. My PC is Beelink EQR6 with the 7735hs and the 680M.
Sorry, i don,t know about the language, Thanks.
daemon6109
