Help with Ryzen 5 (4500U) AMD
What would you recommend? now i got to the apple loading screen with a new EFI but it gets halfway and stay there for 2 hrs. Using MackbookPro 6.1 i7 2.6ghz smbios.
Use MacBookPro16,3.
here's the current EFI. Sometimes the configurator doesn't save the edits. it seems.
Please take a look and see if you can help. It loads to 50% then stop, before getting to the install section.
Your EFI is still not as per the guide. Follow the guide and remove the clutter or build it from scratch!
ploukop
