Help with Ryzen 5 (4500U) AMD
View attachment 8824 got a little further by switching the smbios from macpro 6.1 to ImacPro 1.1 but stuck on a few lines.
imacpro 1.1 stuck on the first screen loaded some verbose codes.
macpro 6.1 2013 shows apple support loads no codes
tried these, no luck :
SSDT-CPUR.aml and use SSDT-CPU-PLUG-ALT.aml instead.
Also, enable DevirtualiseMmio
MacPro? Why use a MacPro SMBIOS? It makes no sense. Neither it makes any sense with iMacPro.
here's my new EFI, still stuck on the same section.
The changes are not present. Please double check.
Also, it seems like the Kernel Patches are not copied properly.
Reactions: Cassiopeia
did you apply the amd patches using opencore configurator? or not? from https://github.com/AMD-OSX/AMD_Vanilla?tab=readme-ov-file#languages-english-current
It may also be because i didn't create an .dmg bootable base on sonoma, I followed yours where you downloaded the latest , which by now is probably sequoia. And that might be the issue.
You should follow the guide to add the Kernel Patches for the AMD systems and also change the CPU Core to match yours.
What would you recommend? now i got to the apple loading screen with a new EFI but it gets halfway and stay there for 2 hrs. Using MackbookPro 6.1 i7 2.6ghz smbios.
I'm stuck here
kocsik
