Is my HP amd laptop compatible for HACKINTOSH? helpppp.
gggg
hey just wanted to clarify if my amd laptop is compatible for hackintosh and installign MAC
model --- HP LAPTOP 16 s0xxx
SPECS--- CPU- AMD Ryzen 7 7840HS w/ Radeon 780M Graphics 3.80 GHz
DEDICATED GPU- RTX 3050 laptop gpu 6gb + i have integrated gpu aswell
RAM- 16 gb DDR5
STORAGE-- 1TB
DISPLAY - 1920x1080 144 hz screen.
can anyone make me a EFI???
pls lemme know if its compatible ....... :)
peace.
RAM- 16 gb DDR5
STORAGE-- 1TB
peace.
macOS can be installed but the Graphics will NOT work. So, kinda pointless.
both dedicated and igpu will not work? i am okay if i run mac on igpu. if i can, can you give some guide about it?
The dedicated GPU is complete unsupported and although there is support AMD APU, the 780M isn't supported as of now.
klklkllkl
