Compatibility of ASUS Dual Radeon RX 7600 V2 OC Edition with macOS 15 Sequoia
jerry
ROG STRIX Z390 E GAMING (asus)
3.6 GHz 8-Core Intel Core i7 ,memmory 32 GB 2133 MHz DDR4(cpu is built myself)
NVIDIA GeForce GT 710 2 GB
11.0.x
Does the ASUS Dual Radeon RX 7600 V2 OC Edition 8GB GDDR6 Graphics Card support macOS 15 Sequoia? Are there any known issues with this card on macOS, especially in terms of installation or functionality?
No, the newer 7000 series GPU aren't supported and they might never be ;(
which GPU models would you recommend for optimal compatibility and performance? I’m looking for something efficient and reliable for macOS.
You can pick from the 6000 series lineup. RX6600 XT, 6800XT, 6900XT
Is the RX 6600 (non-XT version) supported on macOS?
nnaa
