Sequoia 15.1.1 - Install stuck on Apple logo / Gigabyte Z790 Aorus Master / i9-13900K
fl45h
Intel i9-13900K
AMD Radeon RX 6800
15.x
Hello everybody,
I’m new to Hackintosh and want to install Hackintosh Sequoia 15.1.1 on my PC and Im stuck on Apple logo and loader, loader doesn’t move, a few seconds later pc restart
I used “createinstallmedia” command to make my USB (2.0) in MacOS and Open Core.
Can you please take a look at log file and EFI attached and help me if you can ? Thank you
My PC:
MoBo: Gigabyte Z790 Aorus Master
Ram: 128Gb (2x16Gb + 2x48Gb)
GPU: Radeon RX 6800 (RX-68XLAQFD9)
CPU: Intel i9-13900K
LAN: Aquantia 10G Ethernet with AQC113C
00:000 00:000 AAPL: #[EB.H.IS|!] Err(0xE) <- RT.GV boot-signature 7C436110-AB2A-4BBB-A880-FE41995C9F82
00:738 00:738 AAPL: #[EB.H.IS|!] Err(0xE) <- RT.GV boot-image-key 7C436110-AB2A-4BBB-A880-FE41995C9F82
00:826 00:087 AAPL: #[EB|H:IS] 0
00:880 00:053 AAPL: #[EB|LOG:INIT] 2024-11-25T17:57:31
00:932 00:052 AAPL: #[EB|VERSION] <"bootbase.efi 582~2132 (Official), built 2024-09-28T21:19:04-0700">
01:406 00:473 AAPL: #[EB|BUILD] <"BUILD-INFO[401]:{"DisplayName":"bootbase.efi","DisplayVersion":"582~2132","RecordUuid":"8162A91E-C68B-47F2-99D5-2B9A7E354A5B","BuildTime":"2024-09-28T21:19:04-0700","ProjectName":"efiboot","ProductName":"bootbase.efi","SourceVersion":"582","BuildVersion":"2132","BuildConfiguration":"Release","BuildType":"Official","Compiler":"clang-1600.0.25.3","SdkVersion":"15.1","SdkBuild":"24B65","TargetArchitectures":"x86_64"}">
01:460 00:053 AAPL: #[EB.CFG.DEV|!] Err(0xE) <- RT.GV booter-strict-xmlparser 7C436110-AB2A-4BBB-A880-FE41995C9F82
01:512 00:052 AAPL: #[EB|CFG:DEV] r5 0x0 0x0
01:566 00:053 AAPL: #[EB|H:IS] 0
01:619 00:052 AAPL: #[EB|WL:MODE] 0
02:150 00:531 AAPL: #[EB|CFG:ARG] boot-save-log 0x0000000000000002 (0x0000000000000002 < 0xFFFFFFFFFFFFFFFF) default
02:203 00:052 AAPL: #[EB|CFG:ARG] wake-save-log 0x0000000000000002 (0x0000000000000002 < 0x0000000000000002) default
02:256 00:053 AAPL: #[EB|CFG:ARG] console 0x0000000000000001 (0x0000000000000001 < 0x0000000000000001) default
02:309 00:053 AAPL: #[EB|CFG:ARG] serial 0x0000000000000001 (0x0000000000000001 < 0x0000000000000000) default
02:362 00:052 AAPL: #[EB|CFG:ARG] preoslog 0x0000000000000001 (0x0000000000000001 < 0xFFFFFFFFFFFFFFFF) default
02:415 00:053 AAPL: #[EB|CFG:ARG] timestamps 0x0000000000000000 (0x0000000000000000 < 0xFFFFFFFFFFFFFFFF) default
02:468 00:052 AAPL: #[EB|CFG:ARG] log-level 0x0000000000000001 (0x0000000000000001 & 0x0000000000000021) default
02:943 00:475 AAPL: #[EB|CFG:ARG] breakpoint 0x0000000000000000 (0x0000000000000000 & 0x0000000000000000) default
02:996 00:052 AAPL: #[EB|CFG:ARG] kc-read-size 0x0000000000100000 (0x0000000000100000 < 0xFFFFFFFFFFFFFFFF) default
03:432 00:436 AAPL: #[EB|CFG:ARG] force-error 0x0000000000000000 (0x0000000000000000 & 0x0000000000000000) default
03:485 00:052 AAPL: #[EB|H:IS] 0
03:538 00:053 AAPL: #[EB|WL] 0 0 0x01 0x01 0 0x00
03:592 00:053 AAPL: #[EB|BRD:NV] Mac-7BA5B2D9E42DDD94
03:645 00:052 AAPL: #[EB|B:VAw]
03:698 00:053 AAPL: #[EB|B:IAw]
03:751 00:052 AAPL: #[EB|WL] 0 0 0x01 0x01 2 0x00
03:804 00:053 AAPL: #[EB|B:MLBVAR] êêêêêêêêêêêêêêêêêê
03:857 00:052 AAPL: #[EB.BST.IDT|+]
04:297 00:439 AAPL: #[EB.BST.IDT|-]
04:350 00:052 AAPL: #[EB|WL] 0 0 0x01 0x01 3 0x00
04:722 00:372 AAPL: #[EB|WL] 0 0 0x01 0x01 4 0x00
04:775 00:053 AAPL: #[EB|BRD:NV] Mac-7BA5B2D9E42DDD94
04:828 00:052 AAPL: #[EB|WL] 0 0 0x01 0x01 5 0x00
04:881 00:053 AAPL: #[EB.H.CHK|BM] 0x0000000000000000
04:934 00:053 AAPL: #[EB.H.LV|!] Err(0xE) <- RT.GV boot-signature 7C436110-AB2A-4BBB-A880-FE41995C9F82
04:987 00:052 AAPL: #[EB|WL] 0 0 0x01 0x01 23 0x0E
05:040 00:052 AAPL: #[EB.H.LV|!] Err(0xE) <- RT.GV boot-image-key 7C436110-AB2A-4BBB-A880-FE41995C9F82
05:495 00:454 AAPL: #[EB|WL] 0 0 0x01 0x01 24 0x0E
05:547 00:052 AAPL: #[EB.H.LV|!] Err(0xE) <- RT.GV boot-image 7C436110-AB2A-4BBB-A880-FE41995C9F82
05:601 00:053 AAPL: #[EB.H.LV|!] Err(0xE) <- RT.SV- boot-signature 7C436110-AB2A-4BBB-A880-FE41995C9F82
05:654 00:053 AAPL: #[EB.H.LV|!] Err(0xE) <- RT.SV- boot-image-key 7C436110-AB2A-4BBB-A880-FE41995C9F82
05:708 00:053 AAPL: #[EB.H.LV|!] Err(0xE) <- RT.SV- boot-image 7C436110-AB2A-4BBB-A880-FE41995C9F82
05:761 00:053 AAPL: #[EB|H:NOT]
05:814 00:053 AAPL: #[EB|SB:P] 0x0
05:871 00:057 AAPL: #[EB|LIMG:DP] Acpi(PNP0A03,0)/Pci(14|0)/Usb(8, 0)/Usb(1, 0)/HD(Part2,SigC0BF0491-AE8C-4D34-8385-9FD74AA26D93)
05:924 00:052 AAPL: #[EB|LIMG:FP] \System\Library\CoreServices\boot.efi
06:363 00:439 AAPL: #[EB|LIMG:OPT]
06:416 00:053 AAPL: #[EB|RPS] 0 0 0
06:471 00:054 AAPL: #[EB.OPT.LXF|F] <"\\System\\Library\\CoreServices\\com.apple.Boot.plist">
06:524 00:052 AAPL: #[EB.LD.LF|IN] 0 1 <"\\System\\Library\\CoreServices\\com.apple.Boot.plist"> <"0">
06:577 00:052 AAPL: #[EB.LD.OFS|OPEN!] Err(0xE) <"\\System\\Library\\CoreServices\\com.apple.Boot.plist">
06:630 00:053 AAPL: #[EB.OPT.LXF|LF!] Err(0xE)
06:683 00:052 AAPL: #[EB.OPT.LXF|F] <"Library\\Preferences\\SystemConfiguration\\com.apple.Boot.plist">
06:736 00:052 AAPL: #[EB.LD.LF|IN] 0 1 <"Library\\Preferences\\SystemConfiguration\\com.apple.Boot.plist"> <"0">
06:789 00:053 AAPL: #[EB|KF] <"root-dmg=file:///BaseSystem/BaseSystem.dmg">
07:240 00:450 AAPL: #[EB|MBA:CL] <"">
07:611 00:371 AAPL: #[EB|MBA:NV] <"agdpmod=pikera -radcodec amfi=0x80 slide=45 ">
07:664 00:053 AAPL: #[EB|MBA:KF] <"root-dmg=file:///BaseSystem/BaseSystem.dmg">
07:717 00:052 AAPL: #[EB|MBA:OUT] <"agdpmod=pikera -radcodec amfi=0x80 slide=45 root-dmg=file:///BaseSystem/BaseSystem.dmg">
07:770 00:052 AAPL: #[EB.CSR.S|VAR] 0x00000FFF
07:823 00:053 AAPL: #[EB|OPT:BM] 0x0
07:876 00:052 AAPL: #[EB.OPT.LXF|F] <"\\System\\Library\\CoreServices\\PlatformSupport.plist">
07:929 00:052 AAPL: #[EB.LD.LF|IN] 0 1 <"\\System\\Library\\CoreServices\\PlatformSupport.plist"> <"0">
07:983 00:053 AAPL: #[EB|P:CPR] N
08:419 00:436 AAPL: #[EB|P:MPI] N
08:472 00:052 AAPL: #[EB|P:BPI] N
08:526 00:053 AAPL: #[EB.OPT.RKS|!] Err(0xE) <- BS.LocP EDB4A040-6D8A-11EC-8FAD-3E22FB93ADCF
08:578 00:052 AAPL: #[EB|KMR] 223715328
08:948 00:369 AAPL: #[EB.CS.CSKSD|+]
09:001 00:053 AAPL: #[EB.CS.CSKSD|!] Err(0xE) <- RT.GV boot-info-payload 8D63D4FE-BD3C-4AAD-881D-86FD974BC1DF
09:054 00:052 AAPL: #[EB.G.CS|-?] Ok(0)
09:117 00:062 AAPL: #[EB.LD.LF|IN] 0 1 <"<null string>"> <"1">
09:263 00:146 AAPL: #[EB.B.SBS|SZ] 723512
09:719 00:456 AAPL: #[EB|B:SHA] <ef72c338432b63ca44b8c3ae7465a171e7020c9c>
09:772 00:053 AAPL: #[EB.WL.PWLFNV|!] Err(0xE) <- RT.GV wake-failure 7C436110-AB2A-4BBB-A880-FE41995C9F82
09:825 00:053 AAPL: #[EB.WL.DT|!] Err(0xE) <- EB.WL.PWLFNV
09:879 00:053 AAPL: #[EB.WL.PWLFRTC|NONE]
09:931 00:052 AAPL: #[EB.WL.DT|!] Err(0xE) <- EB.WL.PWLFRTC
09:985 00:053 AAPL: #[EB.LD.LKC|D] <"System\Library\KernelCollections\BootKernelExtensions.kc.development">
10:039 00:054 AAPL: #[EB.LD.OFS|OPEN!] Err(0xE) <"System\\Library\\KernelCollections\\BootKernelExtensions.kc.development">
10:091 00:052 AAPL: #[EB.LD.LKC|R.2] <"System\Library\KernelCollections\BootKernelExtensions.kc">
20:259 10:167 AAPL: #[EB.LD.LKFS|-?] Ok(0)
21:210 00:951 AAPL: #[EB.LD.LKC|-?] Ok(0)
21:264 00:054 AAPL: #[EB|BST:REV1]
21:318 00:053 AAPL: #[EB|CSR:OUT] 0x00000FEF
21:372 00:053 AAPL: #[EB.BST.FBS|+]
21:426 00:054 AAPL: #[EB.BST.FBS|ADSZ] 0
21:479 00:053 AAPL: #[EB.BST.FBS|KSSZ] 0
21:532 00:053 AAPL: #[EB|SB:SBGMFNS] x86legacyap.im4m
21:585 00:052 AAPL: #[EB|RH:PF] usr\standalone\OS.dmg.root_hash
21:638 00:053 AAPL: #[EB|RH:MF] <"usr\\standalone\\OS.dmg.root_hash.x86legacyap.im4m">
22:075 00:436 AAPL: #[EB.LD.LF|IN] 0 1 <"usr\\standalone\\OS.dmg.root_hash"> <"0">
22:127 00:052 AAPL: #[EB.LD.OFS|OPEN!] Err(0xE) <"usr\\standalone\\OS.dmg.root_hash">
22:181 00:053 AAPL: #[EB.RH.LRH|P!] Err(0xE) <- EB.LD.LF
22:234 00:052 AAPL: #[EB.BST.FBS|!] Err(0xE) <- EB.RH.LRH
22:287 00:053 AAPL: #[EB|LOG:DT] 2024-11-25T17:57:52
22:340 00:053 AAPL: #[EB|LOG:EXITBS:START] 2024-11-25T17:57:52
Hello everybody,
My PC:
ploukop
