SOLVED Cant boot to the installer for intel
ddccdcdc
HP 82A5
Intel Core i3-7100T
Intel HD Graphics 630 (Kaby Lake-S GT2)
Hi, so I have this issue where I to boot my EFI but it just wont boot. For my previous EFI it got stuck on succesfully initialized AHCPI Controller, now with this EFI it gets Stuck at the Apple logo. With both EFIs my Keyboards Backlight turn off and nothing happans. Here is my EFI. I also tried a lot of EFIs but all with the same appeal. I made my own, used OP Core Simplify and other pre made ones for My Board with no success. Attached are also my Specs.
Thanks.
  • EFI.zip
    EFI.zip
Thanks.
What macOS version are you trying to boot?
Your profile is incomplete. Add the hardware info first!
I'm sorry. It's all updated. Trying to boot Ventura. Also turned on verbose. Here is where I'm stuck at.
What macOS version are you trying to boot? Could you answer that?
If your BIOS Settings are correct, then add SSDT-AWAC-DISABLE.aml and then check. Also, enable LapciKernelPanic+UnblockFsConnect
Also, you should not use the WiFi patch prior to installation. Those are always a post install task!
Like I said. Im trying to book ventura. 13.7. Thanks. Will add!
So I got a bit furher now but it kernel panicked. The log only has one line saying 00:000 00:000 OCS: No schema for Unload at 10 index, context <UEFI>!
What tool are you using to edit the config.plist. Attach the photo of KP.
So first of all. Thank you so much. Adding the file did fix it and I installed it successfully however I did install Sonoma now because of some issues with Ventura. In Sonoma I only have 7mb of VRAM. How do I fix that tho?
Glad to hear. Regarding the Graphics, you'll need to patch the Framebuffer.
kocsik
