ThinkBook 14 g6 with ryzen 7 7730U
desk
Hello people
unfortunately i didnt find any thread related to this cpu model, so i am wondering if i can install macOS on this piece of hardware ?
here are specs:
Display​
14" WUXGA (1920x1200) IPS 300nits Anti-glare, 45% NTSC
Display type​
Antiglare
CPU​
AMD Ryzen 7 7730U (8C / 16T, 2.0 / 4.5GHz, 4MB L2 / 16MB L3)
RAM​
16GB SO-DIMM DDR4-3200 (Two DDR4 SO-DIMM slots, dual-channel capable)
Video​
Integrated AMD Radeon Graphics
Storage​
512GB SSD M.2 2242 PCIe® 4.0x4 NVMe®
Optical Drive​
no optical drive
Audio​
HD Audio, Audio, Realtek® ALC3287 codec, Stereo speakers, 2W x2, Dolby® Audio™
Ports​
USB 3.2 Gen 1; USB 3.2 Gen 1 (Always On); 2x USB-C 3.2 Gen 2 (support data transfer, Power Delivery 3.0 and DisplayPort 1.4); HDMI 2.1, up to 4K/60Hz; Headphone / microphone combo jack (3.5mm); Ethernet (RJ-45); SD card reader
Communications​
Wi-Fi® 6, 11ax 2x2 + BT5.1; 100/1000M (RJ-45)
Battery​
Integrated Li-Polymer 45Wh battery, supports Rapid Charge Pro (charge up to 50% in 30min)
Battery Life​
Models with 45Wh battery: MobileMark® 2018: 9.03 hr; MobileMark 25: 8.68 hr; Local video (1080p) playback@150nits: 13.78 hr;
Weight​
1.38 kg
Dimensions​
WxDxH: 313.5 x 224 x 16.9 mm
OS​
no
Fingerprint​
Touch Style, Integrated in Power Button
Pointing device​
Buttonless Mylar® surface multi-touch touchpad, supports Precision TouchPad (PTP), 75 x 120 mm
Warranty​
3
Additional Information​
Camera: FHD 1080p + IR Hybrid with Privacy Shutter, 2x, Array microphone; Keyboard: 6-row, multimedia Fn keys, LED backlight, English; Power Adapter65W USB-C (3-pin) AC adapter, supports PD 3.0, 100-240V, 50-60Hz; MIL-STD-810H military testing; Aluminium (Top), Aluminium (Bottom)
i would be very grateful for the information
Cheers!
Hello people
here are specs:
Display​
Display type​
Antiglare
CPU​
RAM​
Video​
Storage​
Optical Drive​
no optical drive
Audio​
Ports​
Communications​
Battery​
Battery Life​
Weight​
1.38 kg
Dimensions​
OS​
no
Fingerprint​
Pointing device​
Warranty​
3
Cheers!
Yes, its supported and can be installed!
Reactions: desk
lovely info!
could you please point me to the right guide i need to follow ?
lovely info!
Hey, I am having problems with the same laptop, tried over 30 different EFI and it doesnt work. Same specs. I will pay a reward for EFI that works. WhatsApp Image 2024-10-24 at 9.29.07 PM.jpeg
Hey, I am having problems with the same laptop, tried over 30 different EFI and it doesnt work. Same specs. I will pay a reward for EFI that works. View attachment 8650
Attach your EFI to check. Oh, its built already and working. xD
Hola. Pudiste solucionar ? Encontraste la efi ? Tengo exactamente los mismos componentes y quiero instalar el Mac OS, me puedes ayudar ?
English only!
Hello. Could you solve it? Did you find the efi? I have exactly the same components and I want to install the Mac OS, can you help me?
You can create EFI for your hardware.
kocsik
