SOLVED my Ventura don't works anymore (SOLVED)
ok i will now ty
i will try with 4k on my iphone ..
the video is 393MB (4k) is clear but can't attach..
The system seems to boot fine. What's the issue then?
the boot is fine but then when i log in my account .. after 20 seconds or more i got a black screen and my pc reboot.
sometimes after the black screen.. go again in the login .. i log again and then black screen and reboot.
Seems like a permission issue on the account. Try to login into another account and then check.
ok i will try but it's weird bc was working right before.
I tried, even on the login screen .. if i wait 10 seconds .. the screen go black and then reboot.. i tried to go in the recovery and all works perfect .. so i guess could be the ventura installed, it's weird bc before was working perfect but anyway, i should try to install again ventura?
FIXED! i just enabled the vt-d on my bios and now my usual EFI worked perfectly i could also update the ventura to 13.7
alvarg82
