GUIDE While using SSDT-Time for ACPI table getting error
One step closer to MacOS, I have tried MacBookPro14,3 didnt work but MacBookPro15,1 Worked, So it stated booting up but some error comes and freeze the screen.
I have attached screen shot of the error,
Thank You for Prompt repy, Here I have attached EFI, I have tried to use VoodooPS2Controller.kext and VoodooI2C.kext, none of them worked
I have also attached the snapshot of HID devices
What macOS version are you trying to install? After changing the SMBIOS, did you reset NVRAM?
nnaa
