SOLVED Problems with mounty, mcfuse, and ntfs-3g
Iman
X510UQR
Intel(R) Core(TM) i5-8250U CPU @ 1.60GHz, 1800 Mhz, 4 Core(s), 8 Logical Processor(s)
Intel(R) UHD Graphics 620 and NVIDIA GeForce 940MX
  2. OpenCore (Legacy)
  1. MacBook
Hi admin, it’s been a while. I got so issues with the ntfs read and write partition, before this, I’ve installed and run the mounty app flawlessly, which means I can read and write any files in ntfs partition disk. However, since yesterday, mounty only read those ntfs files and can’t write it. Do you have any explanation regarding these things? Do I need to reinstall those systems mentioned in the title?
Nvm, finally managed it
Did you allow extension in System Settings?
xmax114
