How to Create macOS Sonoma Bootable USB for PC
The following is a guide for creating macOS Sonoma Bootable USB for your PC. The installation has been covered in another section. You can use this USB for a clean install of macOS Sonoma on your PC.
Before you start with this guide, here are a few requirements
STEP 1: Download macOS Sonoma
As macOS Sonoma is not officially released for the general public, but only for developers, you would need an Apple Developer Account along with the Software Enrollment to download a copy of macOS Sonoma. However, if you've not enrolled, you can download an official copy of macOS Sonoma directly from Apple Server using the guide linked below.
elitemacx86.com
NOTE:
If you want to download a DMG file, refer to the guide linked below.
elitemacx86.com
STEP 2: Create macOS Sonoma Bootable USB
The next step is to create a bootable installation drive. Follow the steps below to create the installation media.
1. Insert your USB Flash Drive
2. Open Disk Utility. The Disk Utility is located at
3. Click on View and then select Show All Devices
4. Select your USB Flash Drive in the left pane and click on Erase button. At the top and a popup will appear. Use the following parameters to erase your drive.
Format: Mac OS Extended (Journaled)
Scheme: GUID Partition Map
5. When done, click on Done and close Disk Utility.
6. Launch terminal, located at
7. Execute the command given below in Terminal.
8. When prompted, enter your password.
9. Press (Y) to confirm and then press enter key. It will start erasing the disk and will create macOS Bootable USB
If you're on Big Sur or later, the Terminal may prompt for access. When prompted, click on OK to allow access.
Once the process is completed, you'll see the following screen:
10. Quit Terminal. The USB Flash Drive will be renamed as Install macOS 14 beta.
STEP 3: Prepare OpenCore EFI
At this point, you have a macOS Sonoma Bootable USB ready and you can use it to perform a clean install on a Mac, but it cannot be used to install macOS Sonoma on your PC as you'll still need a proper EFI (including Bootloader and kexts) in order to boot the installer on a PC. Depending on your system, create the OpenCore EFI using the guide linked below. See Chapter 3.
elitemacx86.com
Once you're done with the EFI, you'll need to adjust some parameters which are required for booting macOS Sonoma
STEP 4: Install OpenCore to Bootable USB
Once your EFI is ready, the next step is to install OpenCore EFI to Bootable USB. See the Chapter to install the bootloader to your USB. The guide covers both, UEFI and Legacy installation.
elitemacx86.com
Now, as you have the bootable USB ready, with the right ingredients, you can perform a clean install of macOS Sonoma on your PC.
elitemacx86.com
- A working Internet connection.
- A 16 GB or larger USB Flash Drive.
GUIDE - How to Download macOS Sonoma without Developer Account
How to Download macOS Sonoma without Developer Account Today, Apple announced their new macOS lineup i.e macOS Sonoma 14.0. A copy of macOS Sonoma is currently available to developers who have enrolled in the Apple Developer Program. Users who have not enrolled in Apple's Developer Program...
elitemacx86.com
NOTE:
- If you already have an Apple Developer Account, you can directly download the Beta Access Utility and can use it to download the Installer.
GUIDE - How to Download macOS Sonoma DMG for Clean Install
How to Download macOS Sonoma DMG for Clean Install This guide describes a step-by-step method to download macOS Sonoma DMG for a clean install or upgrade purposes. By following this guide, you'll be able to download macOS Sonoma DMG without a Developer Account and can further use it for...
elitemacx86.com
/Applications/Utilities.3. Click on View and then select Show All Devices
/Applications/Utilities.7. Execute the command given below in Terminal.
sudo /Applications/Install\ macOS\ 14\ beta.app/Contents/Resources/createinstallmedia --volume /Volumes/USB
GUIDE - How to Boot macOS Installer on Desktops and Laptops using OpenCore [UEFI/Legacy] - OpenCore Install Guide
How to Boot macOS Installer on Desktops and Laptops using OpenCore [UEFI/Legacy] - OpenCore Install Guide Booting the OS X/macOS installers on a non-Apple computer can be challenging for new users. This guide is intended for those who wish to use OpenCore as a Bootloader and it covers a...
elitemacx86.com
- The bootloader must be the latest. If you're using Clover, (v5152) or later and if you're using OpenCore (v0.9.3) and later is recommended.
- Kexts must be the latest. The essential kexts are Lilu, VirtualSMC, WhateverGreen, and AppleALC. If you're using some other kext and an update is available, you should update that too. This is mandatory for the installation, ensuring the installer boots successfully and does not run into any problems.
- For AMD Systems, you also need to update the Kernel Patches. Do not use these Kernel Patches if you're using an Intel-based CPU.
- As Apple has dropped the support for older Mac Models (up to Skylake), you'll need to update the SMBIOS data to 2018 and later. See Setting Up SMBIOS for more information.
elitemacx86.com
GUIDE - How to Install macOS Sonoma on PC [Intel/AMD]
How to Install macOS Sonoma on PC [Intel/AMD] The following guide is a complete installation guide for installing a fresh copy of macOS Sonoma on PC. The post-installation has been covered in another section. The required tools and downloads are available at the forum. Overview Apple...
elitemacx86.com
