GUIDE While using SSDT-Time for ACPI table getting error
A.Mihir
Lenovo ideapad 720S-15IKB, Intel Sunrise Point HM175, Intel Kaby Lake-H
QuadCore Intel Core i7-7700HQ
NVIDIA GeForce GTX 1050 Ti with Max-Q Design & Intel(R) HD Graphics 630
15.x
When I select "P" Dump the current system's ACPI tables, Getting following error
I tried several readymade UEFI folders but not working for my laptop hence creating own ACPI table based on system settings.
Is your hardware a PC or a Laptop?
Its laptop and following system info
CPU Type : QuadCore Intel Core i7-7700HQ, 2900 MHz (29 x 100)
Motherboard Chipset : Intel Sunrise Point HM175, Intel Kaby Lake-H
Motherboard Name : Lenovo ideapad 720S-15IKB
Device Description : Intel(R) HD Graphics 630
PCI bus 1 : NVIDIA GeForce GTX 1050 Ti with Max-Q Design
Bluetooth : Intel(R) Wireless Bluetooth(R) (USB\VID_8087&PID_0A2A)
Network Adapter : Intel(R) Dual Band Wireless-AC 3165
Disk Drive : SAMSUNG MZVLB512HAJQ-000L2 (512 GB, PCI-E 3.0 x4)
USB3 Controller : Intel JHL6240 (Alpine Ridge LP 2016) Thunderbolt 3 USB 3.1 xHCI Controller (Low Power)
USB3 Controller : Intel Sunrise Point PCH - USB 3.0 xHCI Controller [D1]
You don't need to do those. Simply create the EFI as per the guide:
I have followed the steps but showing error, Dont know where I was wrong,
I have used alcid=13, and used boot argument -wegnoegpu to disable the GPU
One thing I am not sure I am using USB 3.2 pen drive, I am not sure does it cause the problem, any clue?
Probably, an SMBIOS issue. What macOS version are you trying to install?
I have downloaded MacOS ISO file from Olarila-Sonoma 14.7, I have flashed with BalenaEtcher and replaced EFI folder.
You would need to change the SMBIOS to a supported model such as MacBookPro14,3 or MacBookPro15.1.
Noted I will try again with updated SMBIOS try both one after
One step closer to MacOS, I have tried MacBookPro14,3 didnt work but MacBookPro15,1 Worked, So it stated booting up but some error comes and freeze the screen.
I have attached screen shot of the error,
jkzql77089
