UNable to get my PC Hackintoshed (Solved)
Are you sure that's the correct video link? If so, seems like the EFI is not proper or the NVRAM has not been reset properly. The SSDT-RTC0 has the path PCI0.SBRG but the verbose log says its PCI0.LPCB which is wrong. So, double check that.
Also, you can try the following to reset the NVRAM properly.
Shut down your PC.
Turn off PSU
Wait for 5 mins or more
Power on, reset NVRAM twice. Attach verbose
VID_20240929_102117.mp4
Check please
Remove SSDT-RTC0.aml and SSDT-CPUR.aml and add SSDT-PLUG-ALT.aml.
Okay so I'm rly thankful and so grateful now it's booting .
I am doing a dual boot install, so ofc I'll watch ur video but since every pc needs custom settings, please do tell me what all to enable / tweak after this thing is installed.... Please....
And also, I mean like, I must appreciate your patience and dedication for helping me getting macos installed, you are such a great guy man..... Thank you so so much, just pls do guide me untill the whole process..... As in my last post... 🥰🥰🥰🥰🥰🥰🥰
Also no issues as of now . Just tell me how to do that... Also USB 3.0 ports don't work.... Do i need those UTBMap and USBToolbox? And Audio not working too. Enabled nootedred graphics working bessst.
And pls tell me how can i beautify the efi like in ur videos. It's just black background and normal icons.
That's nice!
Well, what do you have to say now after your post #32?
  • Love
Reactions: ready2000
You're welcome!
As the original issue is resolved, this thread will be closed. You can either create a thread to track all the issues or can create separate thread for each issues you may have.
Off-topic. That's your choice. You can either Hackintool, USBMap or UTBMap.
There are guides available on the forum and the channel for implementing GUI.
  • Love
@EliteMacx86 First of all, what happened to your site for so many days? Secondly, finally everything is working as needed (except wifi and bt ofc and rtx 3050)). I really thank you soooooooooooo much for your help.
THANKS ONCE AGAIN.
That's nice!
Nothing buddy. I am impressed. I love you dude. THANKS A LOT! 💘
Actually I am hackintoshing my other laptop, so probably I'm gonna open a new thread soon and get you to work again 😅, sorry for that beforehand lmao
nnaa
