Stuck on Installation apple logo
!!! SUCCESS !!!
MacOS installed in HDD is not usable in daily life(very low response time), so I deleted it immediately after installing it.
Now I can be iced peacefully⚰️
Screenshot 2024-09-28 at 11.34.47 PM.png WhatsApp Image 2024-09-29 at 09.30.07_059029ab.jpg
MacOS Ventura worked on HP Victus Ryzen 5 5600H - installed on external Seagate HDD
what is working:-
-AMD R5 5600h with Radeon Graphics
-Keyboard(with volume, function, brightness keys, media)
-Optical Mouse
-Trackpad with gestures
-Headphone jack
-All USB ports(Works USB tethering)
-Speakers
-Battery Percentage
-RAM
- Coconut WA04 external wifi adapter (Realtek RTL8188ETV Wireless LAN 802.11n USB 2.0 Network Adapter) with this driver --> Driver Link (speed is very slow but atleast you have wireless internet)
----> MacOS does not lag(0 % lag) but response time is so so so so slow like it takes 4-5 seconds to open Safari and 3-5 seconds to close Safari (all the apps take so much time), booting time is so long due to Seagate Expansion HDD SCSI Disk Device 1 TB (100 MBps RW speed)
----> I found some weird glitches like those shown in the image after installing Chrome and it also happens when I try to change the profile picture of my account on the lock screen
what is not working :-
-internal Realtek RTL8852AE WiFi 6 802.11ax PCIe Adapter
-Bluetooth
-Internal Samsung Nvme m.2 SSD - SAMSUNG MZVLB512HBJQ-000H1
( if you try to open any file from SSD after booting from HDD then whole macOS gets frozen, after that you have to hard restart by the power button, and if you become over-smart and try to formate SSD partition in APFS after booting in into macOS then again whole macOS gets frozen
I don't have stuff and cables for HDMI and Ethernet port so I can't say anything about that 👀
!!! SUCCESS !!!
View attachment 8587View attachment 8588
what is working:-
-Optical Mouse
-Headphone jack
-Speakers
-Battery Percentage
-RAM
-Bluetooth
With APU, the glitches and crashes are expected in chromium based apps.
Oh now APU issues, I am ok with VM at least I am safe, MacOS lags but Response time is a lot faster in a VMware virtual machine 😂
Benefits of VM:-
I can access the Samsung SSD
Win 11 Run simultaneously
Less hardware issue
No efi problems
Benefits of VM:-
Less hardware issue
No efi problems
Yes, VM has their own advantages :)
Need to disable "Use Hardware (or GPU) acceleration when available" from the browser's settings, and it works perfectly.
Alternatively, --no-sandbox can be used via terminal, but it lacks security. @AloneWarrior15
bobawoz
